Lane assist questions
Discussion in 'Gen 5 Prius Technical Discussion' started by daisy555, Aug 3, 2023.
  1. daisy555
    daisy555 Senior Member
    1,715
    708
    CT
    During my test drive I tried slightly swerving over the lane and I didn’t get any warning. I tried both left and right. I’ve been in other cars that actually alert you in an annoying fashion with a noise. Maybe the sound was shut off? How does it work? Thanks
    I did experience the brake assist which was subtle but interesting.
    #1 daisy555, Aug 3, 2023
  2. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    With Safety Sense 2 I get the message on the MID that lane assist is not available under 28 mph.
    But I also don't know exactly what triggers that message to pop up on the MID, except slowing down from driving like 30 or 35 mph than dropping below 28 or 25 mph and it doesn't show up every time slowing down to under 25mph.
    The 2023 Prime is equipped with Safety Sense 3, and the parameters for messages and behavior may have changed for lane assist and a lot of her safety issues.
  3. PhoS
    PhoS Active Member
    252
    203
    Nowhere
    2023 Prius
    Limited AWD-e
    It does chime but only for egregious moves towards or over the lines in my experience. No where near as often as I have seen with older TSS.
  4. Preebee
    Preebee Senior Member
    867
    771
    Midwest
    2023 Prius
    You can adjust that feature based on 3 levels of intensity, or off. I have mine on the lowest setting. Pressing the gas (when going into a corner, or coming up on traffic that is accelerating away), will override it. I love it!
    tovli likes this.
  5. Perpetual Waffle
    96
    120
    Wisconsin
    2023 Prius
    XLE AWD-e
    Yeah, the TSS 3.0 is definitely not super beepy in most driving situations. I think the most beeps I ever hear are when I’m turning and the blind spot sensor is activated (example: two left turn lanes and I am in the right lane and someone is in the lane to my left) or if I put on my signal to lane change while someone is in my blind spot. I haven’t noticed any beeps for lane departure without a signal, mostly because the lane keeping assist has done such a darn good job.
    HacksawMark likes this.
  6. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    This feature would drive a lot of Oregonian nuts since many don't feel the need to use turn signals :LOL:
    PhoS likes this.
