Do active grille shutters use ambient air temp for ecu input?
Discussion in 'Gen 4 Prius Main Forum' started by parked, Aug 9, 2023.
  1. parked
    parked Junior Member
    37
    17
    SF Bay Area
    My ambient air temperature gauge was giving bad readings by about +/- 15°F yesterday, then I got the “Grille Shutter Inoperative” dashboard message. Does anyone know if the active grille shutter system uses the ambient air temperature as an input for the controller? I don’t see any obvious obstructions or damage to the shutter system.
  2. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    Here ya go...
    parked likes this.
  3. Mendel Leisk
    41,522
    Yes, it's monitoring ambient temp for it's operation. If it's cold enough in winter, it'll purposely leave the shutters inoperative and partway open.
    parked likes this.
  4. parked
    37
    17
    SF Bay Area
    Ok, thanks so much for the quick reply! So I wonder if my ambient temperature sensor is giving some out of bounds signal, and the active grille shutter system went into some sort of safety mode. The shutters are open, but I haven’t really evaluated whether they’re 100% open or more like 75% open.
  5. Mendel Leisk
    41,522
    Your avatar pic was how far back? Maybe something damaged or disconnected?
  6. parked
    37
    17
    SF Bay Area
    Excellent information! Thank you guys so much!
    Now the big problem is that I’m on the road 900 miles from home and 500 from my destination with hardly any tools.
  7. sylvaing
    sylvaing Senior Member
    1,210
    514
    Trying to read the grill shutter operation pdf, is there any precedence to the operation? For example, if I'm driving at 70 km/h and it's 38C outside, what will the shutter position be?
  8. Mendel Leisk
    41,522
    Is the shutter message obscuring anything? If not I'd just ignore it till you're home.
  9. parked
    37
    17
    SF Bay Area
    My avatar is a pic of one of our dearly departed Nissan LEAFs. Both smashed and sent to heaven.
  10. parked
    37
    17
    SF Bay Area
    I don’t think the message will be a problem. I’m just worried that the shutters aren’t totally open while I drive through the middle of nowhere in triple digit heat.
