Towing a Prius Prime behind an RV
Discussion in 'Prime Main Forum (2017-2022)' started by Mooney Driver, Aug 10, 2023.
  1. Mooney Driver
    Mooney Driver Junior Member
    I have a 2021 Prime that I want to tow behind my RV. Has anyone towed a Prime using a tow dolly and what are the step-by-step procedures to tow it properly? A lot of conflicting information as to the proper way to tow it. Thanks in advance.
    52,193
    is there anything in the owners manual?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    On a dolly, there should be NO disagreement about what is the "right" way to do it.
    Front wheels on the dolly, rear wheels on the ground.
    What exactly are you worried about ??
    FuelMiser likes this.
  4. Mooney Driver
    The main confusion I have centers around the parking brake and whether I should turn ignition to accessory position? Some say to release the parking brake where others say to engage the parking brake/? which is it? If ignition is on accessory position, will it significantly drain the battery even if you turn off the AC and radio? These are what I am confused about.
  5. Mendel Leisk
    41,752
    I’ll vote car off and parking braking off. The latter in particular seems very obvious.
    Would the RV’s brake lights be obscured by the Prius?
  6. sylvaing
    sylvaing Senior Member
    1,210
    514
    If the rear wheels are on the ground, the obvious answer is to release the parking brake. Don't know why you would want the car accessories to be on. It's going to turn off by itself anyway...
    As for the Prius blocking the RV lights, you can get magnetic brake lights that you put on the roof of the car if that's the case. Although I would worry of it leaving scratch marks on the paint.
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    IF......the parking brake is on the rear wheels, of course it needs to be OFF.
    BUT......if it is electrically operated and automatically engaged when the engine is OFF.......then what ??
    Seems like I remember that Neutral is there mostly for this exact situation and putting it in N should release the
    brake if it is automatically engaged in Park.
  8. Leadfoot J. McCoalroller
    8,121
    7,616
    Pennsylvania
    2018 Prius c
    I've never towed a Prime, but everything I've read suggests that they are "normal cars" from the perspective of a tow dolly, just like every other Prius.
    Thus, the instructions that come with the tow dolly are to be observed, and for safety's sake should be considered the superseding authority.
    In a nutshell, the car should be OFF with the parking brake OFF for compatibility with a tow dolly.
    A detail: You may find that you need to keep the car keyfobs in an RF-tight enclosure. If you have the smart key system, the car notices you approaching and starts waking up systems. But if you are towing the car in an RV, you are never actually that far away from it. The car could get confused and that confusion could drain the 12v battery inappropriately.
    Mooney Driver and Trollbait like this.
  9. sylvaing
    1,210
    514
    In my 2017 Prime, it's a pull string and not an electrical parking brake.
  10. sylvaing
    1,210
    514
    You can hold both buttons (I think that's the combination) at the same time to deactivate the FOB so this doesn't happen.
  11. Trollbait
    12,634
    Why hasn't anybody suggested flat towing it to charge the battery?
    I'm so disappointed.
  12. Mendel Leisk
    41,752
    And then run an inverter to the RV, to power stuff. :coffee:
    Trollbait likes this.
  13. bisco
    52,193
  14. Trollbait
    12,634
    Install a battery bank for power in the RV.
    Then top it all off with solar panels.
  15. Leadfoot J. McCoalroller
    8,121
    7,616
    Pennsylvania
    2018 Prius c
    The typical tow dolly has its own complete lighting system integrated into the trailer unit.
    There is no need to alter the towed car beyond strapping its front tires to the dolly deck.
    Mendel Leisk and sylvaing like this.
  16. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    I think only a tire shop owner would suggest setting the parking brake...you'll need new rear tires in a block or two.
    Ignition accessory position? Why in the world? Anyway, it can't work. The accessory function shuts itself off after a few minutes to save the charge in the 12v battery.
  17. sylvaing
    1,210
    514
    I guess using a dolley for the rear wheels or on a flat bed are the only exception to have the parking brake activated.
  18. rjparker
    10,364
    6,486
    Read the manual. With the Prime being Front Wheel drive and not AWD, the front only has to be on a dolly.
    Disengage the parking brake.
    There are separate emergency towing rules for short distances at 18 mph or below.
    #18 rjparker, Aug 11, 2023
  19. Mooney Driver
    I appreciate everyone's suggestions but if you're following this post, there are as many different procedures suggested as there are respondents to add to the confusion. That's exactly why I'm concerned I might damage my Prime. I don't mean to be rude, but I am really looking for someone who has ACTUALLY towed a prius using a tow dolly to get their feedback as to what to do
  20. bisco
    52,193
    understood, no rudeness taken, all the best!
    Mooney Driver likes this.
