White stuff on spark plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ClammyMantis, Aug 12, 2023.
  1. ClammyMantis
    ClammyMantis New Member
    Your Catalytic Converter
    Hello, long time lurker but first time poster. I recently did a spark plug change at around 190,000 miles. It has always been an oil burner. I was just wondering what the white stuff on the spark plugs mean and if it's a cause for concern. They smell like oil too. Thanks!
  2. OptimusPriustus
    OptimusPriustus Active Member
    328
    137
    Finland
    Cannot see white. Coffee grounds color is normal and doesn’t that plug appear something like that (or is it my display).
    White would normally mean engine running too lean. Dangerously lean.
  3. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    Googling says they are running too hot.
  4. ASRDogman
    ASRDogman Senior Member
    7,243
    3,781
    Lot's of miles on that plug.
    It looks like a built up of the burnt oil.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    Or maybe some additive components of the burnt oil.
    Or maybe some component of the coolant in use.
    I think I'd be a bit concerned about the head gasket.
  6. Tombukt2
    12,215
    2,156
    That's interesting so far none of my generation 3's with the 2 ZFXE engine have been oil burners or users as of yet so far I've got oh I don't know 300,000 on the persona 2013 and the JBL solar roof 2010 is at like 280 in between oil changes on the solar roof JBL is very little maybe a half a quart maybe a half added it 5,000 mi and the other half added at 7,500 possibly. And this car is used primarily for delivery work 24/7. The persona to work and back and lot of parking
  7. Bill Norton
    Bill Norton Senior Member
    2,131
    728
    MONW, Ks.
    This not readable.
    Who understands what you are trying to say?
    It's free to use voice to txt and say the words: Comma, Period, New Paragraph, etc.
    It's called punctuation.
    It's nice for your readers.
    And : It's Free !!!!!!
    Montgomery likes this.
  8. Mendel Leisk
    40,587
    Ever cleaned the EGR?
  9. Grit
    Grit Senior Member
    6,456
    4,189
    Wilkes Land
    I do, I understand. There’s soo
    Much quotes I got from him, I snicker each time I find a new one.
  10. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    They are only running hot if that material is ash like and doesn't wipe off easily... But from this picture, it's possible that it does wipe off easily and you piston rings are leaking oil into the chamber and you headgasket is failing and leaking coolant.
    Was this on all of the plugs or just one or two of them?
    jzchen likes this.
  11. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    I assume the lurker car is USA, where we do not allow metallic fuel additives.
    Lube oil of course has zinc additives.
    I am wondering if these are iridium tipped plugs because they look a bit too worn which could explain the deposits, if not the proper long service plugs
    #11 wjtracy, Aug 12, 2023
  12. sam spade 2
    7,035
    2,799
    2017 Prius c
    Which post are you talking about, Bill ?
    So far, YOURS is the only one that I don't understand.
  13. ClammyMantis
    It was on all of them. Once I get home from work I'll check how easily it wipes off. And for whoever said it's a US car that is correct. I'll take note of the part number in my next response.
  14. ClammyMantis
    So just checked them, it does not wipe off easily.
  15. bisco
    51,155
    he quoted the post he was talking about
  16. bisco
    51,155
    i think it's the o/p's location. what spark plug could hold up to that environment?
    CR94 likes this.
  17. ClammyMantis
    They were Denso SC16HR11's
