Firmware update 2014 plug in prius hybrid
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PriusMomof4, Aug 18, 2023.
  1. PriusMomof4
    PriusMomof4 New Member
    Kansas
    2014 Prius Plug-in
    Hi all! Total newbie here. I adopted a 2014 prius plug in hybrid. I would like to update the firmware if possible. I have downloaded entune and it is useless. Is there somewhere I can download an update? Is it possible to add Spotify to my prius?
    52,096
    congrats and welcome!
    i don't think so. you can contact a dealer about possible updates, and maybe there is info at toyota.com/owners, where you can input your vin and see maintenance history, recalls, updates, tsb,s and etc.
    how many miles on her?
  3. nicoj36
    nicoj36 Active Member
    518
    162
    If you’re looking for apps like spotify, your best bet is to just install an aftermarket android radio.
    bisco and PriusMomof4 like this.
  4. PriusMomof4
    Kansas
    2014 Prius Plug-in
    Any recommendations?
  5. PriusMomof4
    Kansas
    2014 Prius Plug-in
    70k
  6. bisco
    52,096
    read up on egr circuit cleaning
    watch
  7. nicoj36
    518
    162
  8. Mendel Leisk
    41,645
    More on EGR cleaning in first two links in my signature. If you’re on a phone, turn it landscape to see signature.
    It’s a little nuts, but regardless of question 3rd gen Prius owners are asking, it’s become opportune time to warn them of the probable demise of their 3rd generation engine, due to it’s Achilles heel. It’s somewhat akin to “Oh by the way, have you had a shingles vaccine?”
    3rd gen Prius introduced a new Exhaust Gas Recirculation system, which has proven very prone to clog up with carbon, very “reliably”, somewhere between 100k and 150k, and just as reliably the engine head gaskets are failing (disastrous and expensive).
    Toyota has pretty much turned into the 3 uncommunicative monkeys on the subject. Also, there’s much debate here regarding the correlation between EGR clogging and head gasket failure.
    Anyway, warring camps aside :ROFLMAO::cry: my 2 cents: look into it. And if possible avoid dealerships; they’re a hopeless/expensive rabbit hole on the subject. Often, and sadly, DIY is the shortest distance between two points.
    Depending on your location there may be professional options. Tampa Hybrids in Florida, and Hybrid Pit Stop (LA) are two options known here. Which is pretty dismal I know. There may be some local-to-you PriusChat member that can help too.
    70k is pretty much ideal time to get on this, btw.
    Also, if a fair percentage of your miles are electric-only (with the plug-in), it may forestall the EGR clogging. That said, @bisco’s scenario is just that, his miles are modestly more (90k~?), he’s getting engine running rough symptoms, and is currently trading it in AFAIK.
    #8 Mendel Leisk, Aug 20, 2023
  9. PriusMomof4
    Kansas
    2014 Prius Plug-in
    Yikes!!! I'm not at all impressed by my local dealership so they're not touching my car. But that aside, thank you for your warning on the egr system. I'm right in the middle of those! Hahaha Kansas! I am going to get on it now, because I know 100k will come up real fast if I don't! There aren't a lot of hybrids in my state that I'm aware of. Haha I've been looking since I thought of getting the prius. It was hard to find one here. We mostly have trucks. Thank you for the heads up. I've been researching like crazy and no one had mentioned this.
