Toyota oem Prius v traction battery vs Green tc with new cells
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by pvee, Aug 19, 2023.
  1. pvee
    pvee Junior Member
    2013 Prius v wagon
    Our 2013 prius v is worrying us, as the traction battery goes down to the blue bars all the time and it's over ten years old and we just want to get a new battery with new Cells.
    The dealer quoted about 2600.00 when ask one but at that time we weren't as worried about it.
    The Green Tec battery with new cells is about 2600.00.
    Does the Toyota dealership battery have all new cells?
    Thanks,
    Pete
  2. Air_Boss
    Air_Boss Senior Member
    4,218
    1,188
    New Yawk
    How many miles on it? The traction battery charge state will cycle, depending on current draw and duty cycle. Has the charge cycling become extreme? Has your MPG dropped due to ICE runs to charge the traction battery? Is it extremely hot causing A/C use?
  3. rjparker
    10,406
    6,519
    The dealer is only new cells. Others often have used sold as refurbished, reconditioned, repainted (Dorman) or just plain useless (eBay and salvage). However there are lower cost Toyota cells and some independents (if you revealed your secret location) that sell and install for less. Some with mobile services in Texas.
    Alternative new cells are diy and one has low lifespan. The lithium version diy has poor availability and has a recent redesign to cover issues never previously disclosed.
    #3 rjparker, Aug 19, 2023
    Tim Jones likes this.
  4. pvee
    pvee Junior Member
    2013 Prius v wagon
    It runs down to the blue bars just going through a mcdonalds. And it sometimes takes driving 15-20 miles before it starts charging up to one green bar.
  5. pvee
    pvee Junior Member
    2013 Prius v wagon
    Green Tec, lists one of the cities the support. I could replace it myself, just worried about what it there is a problem when I go to start it..!!
    thanks..
  6. Air_Boss
    4,218
    1,188
    New Yawk
    Suggests the Inverter Motor Generator is not operating properly.
  7. rjparker
    10,406
    6,519
    Running down quickly is the classic weak hv battery symptom. The mg will kick on but it is not the issue.
    There are no “new generation high performance NiMH” that are better than Toyota’s. Most aftermarket NIMH cells are Chinese and usually cylinders instead of rectangular. Those cells have not lasted nearly as long.
    You can be sure Toyota cells will last eight to ten years, just like your originals have lasted ten so far. Four years maybe versus eight to ten?
    For the same money buy Toyota. Shop.
  8. Air_Boss
    4,218
    1,188
    New Yawk
    The slow charge recovery rate is IMG related.
  9. bisco
    52,277
    i would get the oem battery, tried and true, but you may be premature. have mpg's declined at all?
    how many miles on her? might not be worth the investment
    is it hot where you are?
  10. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    Sell it......................
