1. mike_az_21
    mike_az_21 New Member
    26
    Arizona
    So, this was purchased as a project since day one.
    It had two fault codes when bought -420(catalytic converter) & a P0A93 - for the inverter pump
    swapped the pump, sold the oem converter before it got stolen & got a cheap aftermarket
    Sometimes the 420 still comes back, which is understandable since I’m using a 57 dollar unit off eBay
    Then after about a week of driving without any probs the p3020 pops up. I cleared it - still gets amazing mpg, runs excellent. The car has zero leaks, was mostly garage kept, all maintenance was done by a dealer. The car is a 2007 Touring with almost 290k, battery was last “redone” about 5 years ago.
    Throughout driving for a week, it popped again about 3x.
    I pull the battery, triple check everything. Founds quite a bit of corrosion. Cleaned everything, load tested every cell - lowest I got one to drop to was 7.49v - some were 7.6 or so, and quite a few 7.7’s
    All back together, again - drives perfect, now seems to charge way quicker. But, out of nowhere - p3020
    Any other input would be appreciated, only thing I’m left with is replacing the battery computer. But, I hate throwing parts at cars.
  2. mike_az_21
    26
    Arizona
    Also to add, when the code pops the car starts running “odd” - it starts pulling all the power from the battery & not recharging - until I clear the code.
    So, I just roll around with a scanner plugged in
  3. PriusCamper
    PriusCamper Senior Member
    12,289
    4,991
    Pacific Northwest, USA
    Go to Google and do a search that looks like this and start reading:
  4. mike_az_21
    26
    Arizona
    Thank you for your reply! It helps in no way possible as the thread that I read days ago.
  5. Brian1954
    Brian1954 Senior Member
    1,980
    777
    South Central PA, USA
    The trouble code from the car, P3020, is telling you what is wrong with the HV battery. Replace one or both of the moduls in block #10 and see what happens OR replace the complete HV battery pack.
    Five years since the HV battery was "redone" is very good. Usually it is a few months to 2 or 3 years until you have problems.
    #5 Brian1954, Aug 21, 2023
  6. mike_az_21
    26
    Arizona
    Even if it tests completely fine?
  7. dolj
    dolj Senior Member
    8,307
    4,245
    Wellington, New Zealand
    It depends on how you're testing them. You assume we know what you did when you say you did a load test. Was the 7.49 V module one of the ones in block #10 perchance?
    mike_az_21 and Brian1954 like this.
  8. Brian1954
    1,980
    777
    Do you have an OBD2 bluetooth adapter that works with the Dr. Prius app? If not, you should buy one and monitor the voltage difference between the battery blocks during hard acceleration ( high amperage discharge ) and maximum regenerative braking ( high amperage charging). This stress on the modules will create a larger than 0.30v difference between the battery blocks and will trigger the trouble code that you have.
    mike_az_21 likes this.
  9. mike_az_21
    26
    Arizona
    Negative, the 10 block checked out completely fine at about 7.68-7.69
    I made a “load tester” with a light bulb & my DVOM - I thought I nailed it, when I found the the lowest one. But, it wasn’t in the ten block.
  10. mike_az_21
    26
    Arizona
    I just came across that actually
    But, I swear I had it when I seen and cleaned down all the corrosion + the cells checked out
    I had my mechanic friend get on it today with his Solus - and, it’s throwing out ABS codes - yet, he couldn’t spot anything on the battery. He refuses to work on these. Lol - he does all my diesel & heavy line work
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    The car is telling you where the problem lies, but you're not believing it........
    block 10 is the 19th and 20th module from the non-ecu end of the battery pack.
    Voltage checks and small load testing do not always reveal the answer.
    Take a look at this thread starting around post 15
    Just Another HV Battery Thread and Experiments | PriusChat
    Brian1954 and mike_az_21 like this.
  12. rjparker
    9,829
    6,067
    Cliff Notes:
    Battery voltage and amp capacity do not always correlate particularly when the problem is more than a discharged cell.
    Rechargeable batteries have a limited number of cycles available. If this was not true there would be built in reconditioning circuits.
    Some modules fail before others providing an opportunity for those who mix and match.
    Eight or more years of reliability requires new cells.
  13. mike_az_21
    26
    Arizona
    I have looked up the codes - but, I really thought the corrosion would have been the culprit - especially after load testing the cells
    I was expecting to find crappy cells in the 10 spot - but, they checked out fine - not even the lowest ones
    it’s still an interesting running project atm - still gets great MPG, but I really expected the code not to come back after cleaning all of the copper & cell connections
  14. dolj
    dolj Senior Member
    8,307
    4,245
    And the "10 spot" is as in the image below?
    Brian1954 likes this.
  15. Tombukt2
    12,639
    2,251
    A lot of times those 10 spot wires if you unbolt them off of the battery flip them over and look at the side that's aiming towards the battery and you'll see green corrosion and one of those wires will be not copper it will be black like it's seen lots of heat black blue whatever I have those wires many sets laying right here in the carport when I test the wires from end to end with an ohm meter etc or so on and so forth they seem to tell me that the own meter which is a high-end model is getting good readings continuity is good electricity is flowing through the wire seemingly okay but that's what I see .. maybe this can be partially some of the resistance and issue I don't know I'm not really a battery person per se but I do know that in other electrical things that I do seeing wires that are blue black as generally not a good thing I need to go look at heating elements and things that are in that circuit to see what is drawing the high amp or high current load a bad heating element something along those lines so I imagining the car's battery and the orange wiring I or we wouldn't want to see blue black copper I would think.
  16. Brian1954
    1,980
    777
    There are 28 modules in your HV battery pack. Toyota groups two modules together to create a block. Toyota uses small wires on each block to monitor the voltage of the block. If the voltage difference between the 14 blocks in your battery pack becomes too large, a trouble code is triggered by the ECU.
    Trouble code P3020 is telling you that one or both modules that make up block #10 are bad. I do not think that you understand where block #10 is located in your battery pack and that there are two modules that make a block.
    #16 Brian1954, Aug 22, 2023
  17. mike_az_21
    26
    Arizona
    Yup, I focused on the wrong blocks. I was counting them backwards.
    I’ll see how she goes - I’m not in the mood to tear it back down again right now.
    But, yeah - I did not really focus on the chrome tabs & that can def be the issue
  18. mike_az_21
    26
    Arizona
    Tore it all down - boy, u sure get faster after your 1st run
    Looked at the 10 block & connectors - nothing. Checked the wires running to the battery ECU - nothing
  19. Brian1954
    1,980
    777
    You are not going to see an internal problem with the two modules in block #10 by looking at the outside of the modules unless the module is leaking electrolyte. One or both of the two modules that make up block #10 are bad internally and need to be replaced.
    You can monitor the voltage of block #10 and compare it with the other 13 blocks by using an app like Dr. Prius or other app like I suggested in post #8 above.
    Also, look at post #11 above again.
  20. mike_az_21
    26
    Arizona
    I’m waiting for my Amazon Bluetooth dongle to get here & go from there
    Load tested them again & the voltage held well.
