2008 priuswon't start after inve cooling pump replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Esterbrookangela2, Aug 22, 2023.
  1. Esterbrookangela2
    Esterbrookangela2 Junior Member
    48
    Oklahoma city
    After a dead 12 v. And cooling pump replacement now my car won't start.. Still has all the warning lights on dash and even the red car with exclamation mark. I thought maybe it might have been bc my head light wasn't plugged in but no such luck. It acts like it's going to but all the lights. I think every warning light is on.. The am2 fuse is good too.
  2. JC91006
    JC91006 Senior Member
    16,827
    8,600
    How did you determine you have a bad inverter pump and battery? Did you read the codes that pointed you to those items?
  3. Esterbrookangela2
    48
    Oklahoma city
    No actually doij on here helped me with that I do have a OBDllreader. That I haven't hooked up yet bc I had taken the negative most on my battery off when all this mess started bc someone told me that it might fix whatever was wrong.. Doij on here said that just cleared out all the codes that would have been on there.. Now that I have replaced the pump that had a big whole in the bottom of it and charged my 12 volt battery now. I tried to start it and all the warning lights and the red car with exclamation still there it won't start. Should I hook up my obdllreader up now? I don't actually know how to do that if you could tell me if sure do it.. Plus I know I have to download Dr proud or something in order to get codes correct?
  4. Brian1954
    Brian1954 Senior Member
    2,402
    962
    South Central PA, USA
  5. Esterbrookangela2
    48
    Oklahoma city
  6. JC91006
    16,827
    8,600
    Did you plug in the new pump? Added coolant?
    The car should be able to start without even a pump in place. So there is something missing here. Are your headlights nice and bright? Maybe the 12v battery is low
  7. Esterbrookangela2
    48
    Oklahoma city
    Update. !!! I checked my orange plug again and I hadn't slid it back down... So yeah!!! It started!!!!sounded really rough at first .. Now can someone tell me how to clear the warning lghts?1 okay well I think they all just went off!!
  8. Esterbrookangela2
    48
    Oklahoma city
    Thank y'all so much for your help I couldn't have done it without you all!!!! Y'all are awesome!!!
  9. dolj
    dolj Senior Member
    8,555
    4,346
    Wellington, New Zealand
    I replied in your other thread, albeit two hours late, for you to check the plug. Glad to see that was the problem and now you're all sorted.
    No problem, we're all glad to help.
  10. JoeDog99
    JoeDog99 Junior Member
    36
    My 08 prius is having the same issue. I checked the codes and got:
    C1241
    C1242
    C1311
    C1377
    C1378
    The mechanic told me it was the hybrid battery but i checked online and none of those codes are for the hybrid battery, they're all for the 12v and brakes/ABS.
    The AM2 fuse was blown as well. Many sites say it is the coolant pump causing the issue, do you think so? I will get a new 12v battery tomorrow to try it but if it does not fix the issue, what else could it be besides the coolant pump?
  11. JC91006
    16,827
    8,600
    you should create a new thread with your specific problem. don't piggy back of this one as your symptoms and problems are different
  12. JoeDog99
    36
    How do i make a new thread? I can't see where to do so and i saw someone on reddit say you need to comment so many times before you can make threads.
  13. ChapmanF
    18,538
    The inverter coolant pump is downstream of the AM2 fuse, but it's not the only thing downstream of the AM2 fuse. If the fuse is blowing, the pump is frequently the problem, but frequently ≠ always.
    Brian1954 likes this.
  14. JC91006
    16,827
    8,600
    select the forum your car is associated with (prius 2nd gen?) Then from there, start a thread under the specific category it falls under. You don't need a minimum amount of comments
  15. dolj
    dolj Senior Member
    8,555
    4,346
