Prius Prime - Lowered on RSR Springs!
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Tweaksalot, Aug 22, 2023.
  1. Tweaksalot
    Tweaksalot Member
    Huntington Beach
    2019 Prius Prime
    Just got my Prime back from the friends over at RSR! They test fit some prototype springs and they are fantastic! Ride feels just like OEM, but no more wheel gap :).
    Djyoshi626, Tatsuya, Roqu3 and 3 others like this.
    52,259
    wow! that looks sweet
  3. purplePriii
    purplePriii Active Member
    275
    122
    What's the ground clearance with the springs?
  4. Agent337
    Agent337 Member
    27
    Orange County, California
    2023 Prius Prime
    SE
    That looks sweet! Looks to be a great balance between reducing the wheel gap while still retaining some ground clearance. I'm looking to get my Prime LE lowered as well and have been trying to get as much info as I can prior to actually going through with it. Are these lowering springs or actual coil overs? How's the ride quality?
    #4 Agent337, Aug 22, 2023
  5. Tweaksalot
    Tweaksalot Member
    Huntington Beach
    2019 Prius Prime
    These are prototype lowering springs. Not coilovers. Ride quality feels just like OEM (honestly I can’t tell a difference really) aside for slightly less body roll in cornering. These seem to be perfect for a daily!
    Agent337 likes this.
  6. Tweaksalot
    Tweaksalot Member
    Huntington Beach
    2019 Prius Prime
    Id have to measure but ground clearance is completely manageable for daily driving. We have an upslope chin so clearance really isn’t that big of an issue. For full transparency my other car is lower than this so I am used to driving lowered cars though.
  7. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Looks good, just the right amount of drop. Did they have to re-align it?
  8. Tweaksalot
    Tweaksalot Member
    Huntington Beach
    2019 Prius Prime
    Nope, drives straight!!!
  9. Agent337
    Agent337 Member
    27
    2023 Prius Prime
    SE
  10. Tweaksalot
    Tweaksalot Member
    Huntington Beach
    2019 Prius Prime
    hey they are prototype springs. I would give RS-R a call directly to see when the production versions come to the US.
  11. LyndonPrius
    LyndonPrius New Member
    2023 Prius Prime
    SE
    Does the prime use different rsr springs than the standard FWD Prius? Thanks!
  12. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    I just installed these springs on my car. Overall it was a pretty straightforward job if you've done springs before. The only part that was different than most was that in order to get to the strut top nuts you have to remove the wipers and all of the plastic trim below the windshield which took me a little bit of time to figure out.
    Super happy with the result. The AWD springs are supposed to do 20-25mm drop in the front, and 40-45mm in the rear. The fender gap is about 1 finger on the front and two in the rear now, not too low for a daily driver. I think it feels a tiny bit more firm and supported than stock but nothing I would consider harsh.
    I was going to do the rear sway bar as well but the Cusco rear bar I received wouldn't work. It was straight where the stock bar has bend in it to go around the motor system. I sent it back for the front one instead, still waiting for that..
    Pics later, it's absolutely atrocious outside at the moment.
  13. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Caught a break in the rain long enough to snap a picture. (y)
  14. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Picture broke, reuploading..
  15. Ken Brandel
    Ken Brandel New Member
    Chula Vista
    2023 Prius Prime
    XSE
    So you didn’t have to get the camber adjusted after installing the springs?
  16. Justin Prius AWD
    Justin Prius AWD Junior Member
    37
    2024 Prius
    Limited AWD-e
    Looks great! I ordered a few suspension items from TMR and will have them installed in a few weeks. Looking forward to the new look and feel.
  17. RightOnTime
    RightOnTime Senior Member
    790
    1,660
    183
    Kidnapped in OC, CA
    Looks good! What is next on the list?
  18. RightOnTime
    790
    1,660
    183
    Kidnapped in OC, CA
    Our Shop (Hybridpit) has installed about 5 sets of springs so far. RSR USA comfirmed the fitment but they only had 1 set to do that It will be readily available for the US market once the cargo container comes in
  19. Agent337
    Agent337 Member
    27
    2023 Prius Prime
    SE
    Looks like your shop in Buena Park, I think I might have to contact you guys soon!
    RightOnTime likes this.
  20. Chi_weezy
    Chi_weezy Junior Member
    35
    Sacramento
    2024 Prius Prime
    Car looks great. What is the exact tint specs if you don’t mind? Same tint on front and rear doors? Taking mine in asap and yours looks great.
