rear seat vents
Discussion in 'Gen 5 Prius Technical Discussion' started by AndersOne, Aug 26, 2023.
  1. AndersOne
    AndersOne Active Member
    334
    193
    Europe
    2023 Prius Prime
    A lot of reviewers are complaining about missing vents for the rear seats. At least according to the manual, there are "optional" vents for the rear seats below the front seats.
    Does anyone know which markets are getting these? At least for people already having a Prius it shold be easy to check.
    #1 AndersOne, Aug 26, 2023
    otatrant and KMO like this.
  2. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    351
    272
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    2023 Prius Prime XSE (Southeast Toyota USA):
    Under Drivers Seat Rear:
    Under Passenger Seat Rear:
    otatrant, AndersOne and KMO like this.
  3. hill
    8,732
    Easily confused, was thinking this conversation was going to be about ventilated perforated leather seats - where AC cooled air is blown all across your backside. If that was aftermarket that would be "cool" ... pun intended.
    #3 hill, Aug 26, 2023
  4. AndersOne
    334
    193
    Europe
    2023 Prius Prime
    Thanks for the check! I would assume these are pretty standard then for most markets.
    Sure, they are not as good as explicit ones in the middle console but reviewers always sounded like people in the rear will die from heat or cold.
  5. Hammersmith
    Hammersmith Senior Member
    2,206
    2,214
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm loving the ventilated front seats in my Limited. I think that makes the Limited trim worth it all on their own. ;)
    Limited has the rear floor vents, btw. I'm guessing all US trims do, but we need an LE and/or SE owner to chime in.
    friyet and mountaineer like this.
  6. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    Might be a silly question, but does the HVAC have to be on “feet only” to get the air into the back floor area with those above mentioned vents?
    Hvac set to “full auto”, would the rear passengers get full auto through those floor vents? Wondering, but I would assume yes.
  7. Tideland Prius
    16,506
    Those are "rear seat heater ducts" and has been standard on all cars since the late 90s or early 2000s (I do remember them being optional on the late 90s Cavaliers so I think those were the last few cars to have had them as optional equipment).
    The "rear seat A/C vents" that people are asking for, are for cooling - so they're usually located at the back of the centre console or on the B-pillar.
    Yes (or at least some combination that includes the FOOT position).
    Yes in the winter. The HVAC typically heats your feet in the winter as warm air rises and a warm foot tends to make you feel warmer overall than if you were to blast your face with heat but your feet is cold.
    Blizzard_Persona and Trollbait like this.
  8. AndersOne
    334
    193
    Europe
    2023 Prius Prime
    As for the optional I got the idea from the "if equipped":
    Its clear what the people were asking for but are you sure the "rear sear heater ducts" are only for heating? Why not cooling as well? The manual doesnt mention any difference
  9. Tideland Prius
    16,506
    I’d be very surprised if it was optional. It’s possible this manual is not just for Canada and US but also Mexico.
    Typically it’s for heating but sure by all means, turn on the A/C and change the MODE to “FOOT” if you wanna blast your feet with cold air. It just won’t do it automatically cause it doesn’t make sense.
    AndersOne likes this.
  10. yarrh
    yarrh Junior Member
    17
    NYC
    2023 Prius
    Limited AWD-e
    I can confirm that air only blows out of those ducts if the “lower” airflow setting is enabled.
    None comes out in the “upper airflow only” setting.
    Should be the case whether it’s fan, cooling, or heating. But will check and confirm later.
  11. Trollbait
    12,446
    The manual is written for the global market. The spare tire is an "if equipped" bit in it, and I don't even think it's an option in the US.
  12. yarrh
    yarrh Junior Member
    17
    NYC
    2023 Prius
    Limited AWD-e
    Ive confirmed that it blows out with the lower air setting in any mode (heating/cooling/fan).
    Blizzard_Persona and AndersOne like this.
  13. AndersOne
    334
    193
    Europe
    2023 Prius Prime
    FYI so apparently in japan you have to buy the cold weather package for "rear heater ducts":
    vvillovv likes this.
  14. Sharol
    Sharol Member
    161
    74
    Kansas, USA
    2023 Prius
    Limited/USA: No idea if these are heat vents, but they look like pictures I've seen.
