2005 Prius Traction Battery 130F
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wbeck, Aug 27, 2023.
  1. wbeck
    wbeck Junior Member
    Atlanta, GA
    As the titled says, my traction battery overheated (to at least 130F) and the triangle of death and a couple of other orange lights came on. I have a 2005 Prius with 206,000mi. After this happened, the car was still driveable and I was close to home. When I got home, I plugged in my Veepak ODBC and ram Dr. Prius which showed 130F and an error code P3000 P0A82. The battery is a Green Bean installed 7/7/2021. Here are the troubleshooting steps I've performed:
    • Used Dr. Prius to clear the error. I drove the car again and the warning lights did not come on. However, the battery heated up to 121F. As far as I could tell, the battery fan did not com on.
    • Got home and took everything apart so I could visually see if the battery fan was turning.
    • Checked the hybrid battery vent and black air tubes. I actually took it all apart and verified there was no dirt/hair or other obstructions.
    • Checked the squirrel fan/hybrid battery fan. It was very clean from when I cleaned it a couple of years ago.
    • Turned on the car and used Dr. Prius to cycle through different battery fan speeds. All speeds worked which were based on the sliding temperature I moved in the Dr. Prius app.. However, at the top fan speed, the fan turned off after a few mins (this may be normal operation...idk).
    • Ran a Life Expectancy test using Dr. Prius. It reported the battery had 60% left.
    What in the world could be wrong?
  2. Mendel Leisk
    41,512
    Are you sure that’s overheating? I’m not sure myself, and it’s been a while since I monitored battery temps (on my third gen). They do heat up, significantly over ambient.
    Have you checked condition of the fan?
  3. bisco
    51,994
    so with the car running, did the fan run, or just manually with doc prius?
    is the intake grille clear?
    could be a weak module overheating under stress, then sets the codes
    wbeck likes this.
  4. wbeck
    wbeck Junior Member
    Atlanta, GA
    @Mendel Leisk , I am reasonably sure that the overheating hybrid battery caused red triangle,etc as the codes it threw pointed to a generic hybrid battery problem P3000 and a problem with the fan P0A82 (Hybrid Battery Pack Cooling Fan 1 Performance/Stuck Off). But I could be wrong. Dr. Prius displayed the temp in red. Then it changed the.color to green when the temp dropped below 120F.
    @bisco , the vent grill is clean as a whistle. I'll need to do a 25min drive to make sure the fan comes on again. I have taken the cover off so I'll be able to see the fan spinning.
    It may have to do with its temperature sensor. But I don't know where or what part that is on the hybrid fan system.
  5. Mendel Leisk
    41,512
    You’ve checked the fan for lint then?
  6. wbeck
    wbeck Junior Member
    Atlanta, GA
    Yes, the fan is very clean. It's white. Thank you!
  7. Brian1954
    Brian1954 Senior Member
    2,229
    877
    South Central PA, USA
    Some of the cells inside the modules of the battery pack are going bad, which are causing the overheating, is my guess.
    So, the refurbished Green Bean battery lasted just over two years. That is about the average for a refurbished battery. Do you have a lifetime warranty or a three year or more warranty on it?
    wbeck likes this.
  8. wbeck
    wbeck Junior Member
    Atlanta, GA
    That is a very interesting hypothesis, @Brian1954. Thank you for your thoughts. I also thought this might be a possibility. I used Dr. Prius to perform a Life Expectancy Test today, which consists of reving the engine to fully charge the battery and then keeping the current use (I think) steady for 5-10 mins by turning on the headlights and AC. Thats where i got the 60% life expectancy value (see attachment). It didn't report any bad cells, but this could have been a fluke.
    I am attaching the Dr. Prius screenshot from when it overheated and the red triangle of death appeared with a couple other lights - on my way home. When I got home 2 days ago, I ran Dr. Prius and saw the over-heated battery. It occurred to me that there may be a possibility of fire if the battery gets too hot.
  9. wbeck
    wbeck Junior Member
    Atlanta, GA
    Yes, I have a lifetime warranty on the Green Bean battery. It may be that I need to run more tests...drive it for 30mins to see if the fan comes on or if the battery overheats again.
    #9 wbeck, Aug 27, 2023
    Brian1954 likes this.
  10. wbeck
    wbeck Junior Member
    Atlanta, GA
    I just wanted to thank everyone for your expertise. I drove the 2005 prius today for about 30min. The battery fan came on and its speed even varied. The battery did not overheat. I might have to drive it for an hour. I have attached a pic of my battery fan and the battery. I circled 3 holes on the battery that air is being blown out of. I guess this is normal??
    If it overheats again, it may very well be an indication that the hybrid battery is going bad. Thanks again!
  11. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Not normal. Those three (3) holes should have white colored clips that hold the interior piece in place. Cover them with tape, or the clips.
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,975
    NJ-USA
    Do you see the white connector above and to the right of the fan motor? There is green corrosion on at least one of the pins. The black wire carries power to the fuel pump. The other three are for the battery fan.
    I suggest you carefully splice all the wires to eliminate that connector. Then clean and seal the cracked body filler around the upper tailgate frame. It's a common problem on a Gen2. Minor cracks around the tailgate strut mounts on the body, up to the rain channels under the rubber strips. Do a search of the forums for more info.
    SFO likes this.
  13. Mendel Leisk
    41,512
    Just a wild guess: it does not seem normal, if that is the only route the air can exit. I’m not familiar with the 2nd gen ductwork (and it’s been a while since I cleaned our 3rd gen’s).
    Could be air has some other, much more generous exit route. On the other hand, if air is really blasting out of those tiny holes, maybe there’s a blockage in that normal route?
    ultimately the air exits through two openings at the rear corners of the hatch area.
  14. wbeck
    wbeck Junior Member
    Atlanta, GA
    I have covered the 3 holes on the hybrid battery with black electrical tape.
    Hmmm, I didn't notice the green corrosion on the orange wire until you mentioned it. I'm not sure this was the problem as the battery fan was powering on, but corrosion is never good. I'll look into the separate cracked body filler issue. I'll be driving the vehicle for about 90mins this weekend so it'll be a good test.
  15. wbeck
    wbeck Junior Member
    Atlanta, GA
    Update: It may be likely that the corrosion on the green wire is causing my battery fan to run intermittently. Today, I started driving and the battery fan came on when I started my car - the battery temperature remained low throughout my drive. This happened bc I had Dr. Prius running and set the battery to run at max speed.
    However, when I drove back home, the fan did not come on and the battery temperature rose to about 110F. I was not running Dr. Prius.
    I found the battery fan wiring diagram in another post. It appears that the battery fan is controlled by voltage.
    A temporary fix is to run Dr. Prius and set the fan to max. A permanent fix likely means splicing wires that have corrosion.
    #15 wbeck, Sep 1, 2023
  16. wbeck
    wbeck Junior Member
    Atlanta, GA
    I don't think covering the 3 battery case holes with tape did anything, btw.
  17. pasadena_commut
    pasadena_commut Senior Member
    2,656
    789
    Southern California
    I wouldn't expect it to. The material that forms the floor of the hatch area is going to sag down and mostly block those holes. Even if it didn't their total area is very small compared to the area of the exit vent, so a pretty small fraction of the cooling air would leak through them. That said, get replacement clips and put them in or keep the holes taped - it will help to keep dirt, lint, and the like from falling into the pack.
  18. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    Those three holes are to capture the push clips that should be on the underside of the floor panel. They are notoriously hard to extricate the first time.
    For reference, the clips are part number: 90467-10161. These are very common and used all over Toyota models. No doubt you can pick them up in a clip pack for cheap.
    wbeck likes this.
  19. pasadena_commut
    2,656
    789
    Southern California
    When I lifted that flap to get at the pack fan those clips were super fragile. That plastic does not age well, at least in hot Southern California.
    wbeck likes this.
  20. wbeck
    wbeck Junior Member
    Atlanta, GA
    Thanks, I went ahead spliced the black wire and the brown wire bc there was a lot of corrosion. Unfortunately, the battery is still overheating. I saw the fan come on (at a very low speed) when I started the car. My guess is that the fan is not registering the voltage changes to change its speed. Again, if I run Dr. Prius, I can set the fan to max speed while driving.
