Transponder Issues (?)
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by PixelRogue, Aug 27, 2023.
  1. PixelRogue
    488
    86
    US
    Hello everyone,
    Few months back I started getting a dashboard alert icon w/message "KEY NOT DETECTED" followed by message to place in park, touch start button w/transponder. When this interruption happens, it can take several minutes and tries to get the car started. Last night car started but displayed key not detected message the entire trip.
    First response was to presume this was battery related. Replaced the battery, and while issue may have appeared less, it is still appearing. Same started happening for my wife, replaced her transponder battery and message still appears.
    Thinking now this either has to be something related to the transponder system on the Prius, or possibly a batch of bad batteries (not sure how to test those little button batteries.)
    Anyone come across this persistent issue?
    52,390
    Brian1954 likes this.
  3. PixelRogue
    488
    86
    US
    I actually have a multi tester .. what settings then for the button battery?
    These are new batteries so would be surprised if they are low...BUT..would rather battery than other things.
    And if it is NOT battery related, what next?
    #3 PixelRogue, Aug 28, 2023
  4. bisco
    52,390
    on mine, it's just dc. on some, you might need to find voltage range for 3.3v, idk
  5. PixelRogue
    488
    86
    US
    https://www.techwalla.com/articles/how-to-test-a-button-battery
    It is odd because there are times, like this morning where the responder doesn't work at all... had to manually pull out key from transponder to lock... and then two hours later transponder working like new....from the same battery. Will test soon.
  6. Air_Boss
    Air_Boss Senior Member
    4,224
    1,188
    New Yawk
    How old is your 12V auxiliary battery?
  7. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    VDC, if not auto range select one with 4 V in it and the lowest maximum.
    Those tiny batteries are strange, 3 V is basically when the little low battery lights start blinking on the keys/transponders with indicators…
