2008, What Else Can Be Done to Improve Fuel Economy?
Discussion in 'Gen 2 Prius Fuel Economy' started by Ozzbo, Aug 25, 2023.
  1. Ozzbo
    Ozzbo New Member
    29
    Austin
    Gen 2 2008. Changed spark plugs, air filter, cleaned MAF and throttle body. The cat had been stolen, then a replacement was installed. Mileage is 148,000 miles. Before and after the cat was stolen, the mpg was 45-48. One day after Costco gas filling the mpg dropped to 41-42. Tires are 40 psi. Driving is very gas saving. No acceleration. What else can be done to improve mpg? Thanks.
  2. dolj
    dolj Senior Member
    8,458
    4,294
    Wellington, New Zealand
    You need to give it time. I never take much notice of the MFD figure until there are 200-300 miles on the tank. I only compare MPG for full tanks with each other.
    #2 dolj, Aug 26, 2023
    Data Daedalus likes this.
  3. Ozzbo
    Ozzbo New Member
    29
    Austin
    Should I clean the battery fan? Can that help with increasing mpg?
  4. bisco
    52,093
    absolutely, if it's dirty
    air filter?
    #4 bisco, Aug 29, 2023
  5. Ozzbo
    Ozzbo New Member
    29
    Austin
    Yes sir, changed!
    Data Daedalus and bisco like this.
  6. Ozzbo
    Ozzbo New Member
    29
    Austin
    One day, a Check engine light came up. After 2 days it disappeared. Recently I read the errors with Torque Pro app, and it showed the P0101 error (MAF sensor). I cleaned the MAF again and reset the error. I will update on the consumption later. At the moment I have almost 400 miles run with 2 units of fuel rest. Hopefully, I will make 500 miles.
  7. Ozzbo
    Ozzbo New Member
    29
    Austin
    I had a long trip about 500 miles. MPG has grown from 42.3 to 45.5. The speed was in a range 60-70 mph.
  8. Classic Car Guy
    Classic Car Guy Active Member
    449
    123
    Northwest, USA
    My 2007 had a big reaction to 45-47 mpg after the replacement of the stolen cat. It didn't took long and after a year it went back to 40-43. Mine does more mpg in the hway than street. I don't know why? By the way I'm using a bigger tire instead of the original 185. I still have the original tires brand new and I tried it one time during winter. I cant stand the ride. I don't know why?
    Been like that since when I bought it 98k miles. Now is 151k. I consider the car running very good to excellent. The tire wear in my car is not even 50%. I can easily do a decent 25k as long as I don't get screwed with a big nail.
  9. Ozzbo
    Ozzbo New Member
    29
    Austin
    After couple days of accurate city driving, I got 46.5 mpg which looks normal to me.
  10. Ozzbo
    Ozzbo New Member
    29
    Austin
    After replacing the MAF sensor, MPG gradually reached 55-56. Before, there was an occasional Check engine light pointing towards the MAF sensor.
