2003-2009 Toyota Prius 2nd gen: steering wheel control buttons not working?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 1000uf, Sep 4, 2023.
  1. 1000uf
    1000uf Junior Member
    Italy
    I had a 2nd generation Toyota Prius which had all the control buttons on the steering wheel not working. My regular mechanic suspected that it was the steering wheel sensor assembly cable which was defective. It turns out that he was correct. I made a quick video to show you this repair:
  2. Tombukt2
    13,290
    2,398
    Very common 45 minute repair
    1000uf likes this.
  3. bisco
    52,286
    and get oem, aftermarkets fail quickly
    1000uf likes this.
  4. Primetime Paul
    Primetime Paul Junior Member
    31
    I discovered my Defrost buttons dont work, but they work when the wheel is turned more than 45 degrees. Might need a clock spring soon, all the other buttons work so it's low priority for me.
    1000uf likes this.
