Max cargo dimensions?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by emerald, Sep 1, 2023.
  1. emerald
    emerald New Member
    ca
    I'm looking to buy a prius with car camping as my top priority and can't find a general thread for the PIP dimensions with seats down/front seats pushed all the way up and if these dimensions differ between a 13 and a 15 for example.
    52,362
    they are all the same. i can measure the back of mine tomorrow if you want.
    keep in mind gen 3 (2010-2015) has a head gasket issue
  3. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    About 6'7" long. 3'3" wide at the narrowest point between the shocks. Cozy for two. Spacious for one. You need to get the right tote, etc. set-up for behind the front seats to build that area up to a flat surface.
  4. Mendel Leisk
    41,874
    Front seats pushed all the way forward (and presumably fully upright) dimension will avoid the vagaries of seat adjustment, but you’ll need to take it with a grain of salt; driving the car with the seats thus would be very uncomfortable, maybe dangerous/impossible. Maybe get that dim, then deduct 4~5 inches.
    Recent load in our non-plug-in attached; the stacked tires are 25” OD, and rims are nominal 15”. Front Seats are just in their regular position, maybe halfway back, tilted back a couple of clicks. The rearmost rims are about as far back as possible; if they were any taller they’d prevent the hatch closing.
    BTW, driving with hatch open you get a relentless beep. I did this once, thought I could spoof hatch closed by pushing a carabiner into the latch, but either you can’t or I just didn’t have optimum carabiner shape. I just endured it.
    #4 Mendel Leisk, Sep 7, 2023
