For Sale 4th gen 15" OEM wheels + Xice tires
Discussion in 'Private Sales' started by MTN, Jun 12, 2023.
  1. MTN
    MTN Active Member
    306
    276
    SB, CA
    Great condition, set of 4 wheels and tires with less than 8k miles on them. X-ice Xi3 version, I believe.
    $400
    pickup in Santa Barbara, CA 93110
    4th gen / Prius Prime OEM 15" wheels
    MICHELINĀ® X-ICEĀ® XI3 195/65r15 tires winter / snow / ice
    Stored 10 months a year, bagged and air vacuumed out - I want my items to last.
    No TPMS, no centercaps.
    #1 MTN, Jun 12, 2023
    TGrracie and TeddyYaki like this.
  2. MTN
    MTN Active Member
    306
    276
    SB, CA
    More pics
  3. TeddyYaki
    TeddyYaki New Member
    Sacramento, CA
    Can anyone confirm if these fit a gen 3 Prius? I was at the auto dismantler today and he swore they wouldn't.
    MTN likes this.
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    They will fit.
    The only problem would be between the Prius v wagon wheels and the regular Prius hatchback wheels as they are 5 x 114.3mm vs 5 x 100mm bolt patterns. Perhaps that's what caused the confusion on the part of the wrecker employee's understanding of compatibility.
    TGrracie, Mendel Leisk and MTN like this.
  5. MTN
    MTN Active Member
    306
    276
    SB, CA
    Thanks xliderider for confirming.
    Now's the time to buy for next winter! Only selling b/c we need the storage space back and we got an AWD Sienna.
  6. xliderider
    8,140
    3,280
    Honolulu, HI
  7. MTN
    MTN Active Member
    306
    276
    SB, CA
    LOL - yep! Not the best seller's market here.
    We put them on for a snowboard road trip to SLC, Jackson and other areas - Big Sky once, Sun Valley another time. Funny how in those parts we were the only non-truck it felt like. Snow tires worked great when it was 14* and blowing snow while driving from one mountain to another. Def. worth the investment (wheels and tires were easily paid for with MPG and cost savings vs renting a vehicle and/or flying)
    TGrracie and xliderider like this.
  8. MTN
    MTN Active Member
    306
    276
    SB, CA
    bump - $350
  9. MTN
    MTN Active Member
    306
    276
    SB, CA
    $350 - it'll be winter before you know it...
  10. MTN
    MTN Active Member
    306
    276
    SB, CA
    bump - someone, somewhere wants these!
  11. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    When using these tires on your trips did you encounter any R2 or R3 situations (4wd or chains mandatory)? I'd buy them to drive to Reno up 395 but want to be sure I'm not going to be ticketed. I've driven in bad conditions with regular tires and just laughed off the legal requirements but if I'm going to buy the tires I want to be pretty sure they'll keep me legal also. Thanx
  12. Mendel Leisk
    42,380
    Snow tires are almost invariably all you need. I've never used chains, never encountered a road where they were required. From reading here, @fuzzy1 says (paraphrasing), that if chains are required, perhaps you shouldn't risk it. Especially in a low slung Prius.
    Tire sellers would be a lot less ambiguous showing a pic with a tread-depth gauge ($2~3 at automotive supply stores, or Amazon). Lincoln's head almost buried leaves me somewhat bewildered.
  13. JohnPrius3005
    423
    235
    Sorry, I should have been more clear. My question about legality experience was intended for the original poster, MTN. Thanx
  14. MTN
    MTN Active Member
    306
    276
    SB, CA
    Sorry just noticing your question now. We never ran into chain restrictions on our trips - mainly b/c we were in other states.
    For CA driving, it is advisable to carry a set of cheap cables to help get through any restrictions. I know that the x-ice do much better than crappy all-seasons + cables though! Unfortunately CA DOT doesn't take into account real winter tires vs M+S - so these tires will keep you safer, but you might still have to install cable chains if the local authorities insist. (side-note - we would be willing to throw in a set of the super Z cables if you buy these!)
    jzchen and BiomedO1 like this.
  15. JohnPrius3005
    423
    235
    Hi MTN, Let's talk. I'll send you a private message with my contact info.
    MTN likes this.
  16. BiomedO1
    4,639
    2,434
    Left Coast
    Driving in the Tahoe Basin & Reno area for the past three decades - Cal Trans makes NO exceptions. You either have to have a 4x4 or AWD to get past chain controls. You must have a 4x4 or AWD emblem, somewhere on the car - otherwise the kids running chain control checks won't let you through.
    I've slipped through a few times with my FWD w/M+S tires and it was pretty hairy. Just had to give the stupid flat landers a LOT of space for them to spin themselves out....
    MTN likes this.
  17. JohnPrius3005
    423
    235
    Hi Biomed,
    Thanks.
    Yeah I used to drive my VW Scirocco back and forth to Mammoth from LA a lot. I got quite good at installing cables - which chew the hell out of the shoulder of tires.
    More recently I snuck through from San Diego to Palm Desert at the height of the early 2023 winter storm on mountain roads - my Prius without chains. It was pretty high risk and exciting as can be. I made it where guys with pick ups were spinning out. Helps to have regen braking instead of "calipers clamping discs" to slow down I think. It was too early in the morning for chain control checks to be manned ;-)
    I appreciate the definitive info - no exceptions. Well noted.
    Aloha
    MTN likes this.
  18. MTN
    MTN Active Member
    306
    276
    SB, CA
    Sale pending!
    and *SOLD* to a nice PriusChat'r
    #18 MTN, Sep 12, 2023
