JBL vs standard sound
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by kellyj, Aug 23, 2023.
  1. kellyj
    kellyj Junior Member
    43
    22
    Orlando, fl
    2019 Prius
    Anyone have an opinion on the 6th gen standard audio vs the 5th gen JBL audio? I am looking at an XLE that is loaded but no JBL - I had JBL in my 3rd gen and had standard in my 4th gen but upgraded the receiver to a kenwood with electronic cross over and there was a huge improvement - I am wondering if I will regret not getting the JBL? Do you think it's worth the difference or would I be better off with amp and cross over - I am not into super load music just don't want it to sound like garbage.
  2. AndersOne
    AndersOne Active Member
    335
    195
    Europe
    2023 Prius Prime
    JBL is not available in Europe and I think its not available in Japan either. Given these markets have overall better equipped Prius (PHEV) compared to America, I can only guess the JBL addition is nothing to write home about and the standard audio is good enough. As other reviewers mentioned, the JBL speakers look like a cheap afterthought glued to the a-pillars.
    Anyway, just a guess.
    #2 AndersOne, Aug 31, 2023
  3. Tiberius
    Tiberius Junior Member
    Toronto
    2023 Prius Prime
    XSE Premium
    I don’t know what the standard sounds like but I am fairly particular when it comes to music and I can say that the JBL sounds quite good. I was actually quite pleasantly surprised - for example fairly deep bass, no distortion at loud volume, rich and balanced sound overall. Not exactly aftermarket sound but pretty impressive nonetheless.
    hyperphil likes this.
  4. Jim Call
    Jim Call Active Member
    106
    113
    Asheville
    2023 Prius
    You can't get the JBL system on either an LE or XLE, only Ltd.
  5. Gokhan
    Gokhan Senior Member
    6,467
    2,582
    Paramount CA
    With the JBL, you get an amplifier and JBL speakers. Without the JBL, you don't get an amplifier and are limited to the output power of the DENSO/DENSO TEN multimedia unit.
    I have JBL on my 2021 Prius Prime Limited. I didn't have JBL on my 2020 Prius Prime XLE. JBL has a very strong bass, which any music listener would appreciate. Yesterday, when I was listening to Sultans of Swing in my car, I realized for the first time how prominent the bass in that song was.
    So, yes, if you could make a choice, definitely go with JBL over stock. It is not to say that JBL is a very good sound system, but it will be better than the nonamplified stock audio.
    #5 Gokhan, Sep 7, 2023
  6. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    I can say The JBL is quite good I use Apple Music through car play, has good Bass, Vocals are clear! Spend a few bucks more for a Limited, power rear hatch, 12.3 info screen, JBL, heat and ventilated seats!
    CeruleanBlue, TGrracie and Gokhan like this.
  7. AndersOne
    335
    195
    Europe
    2023 Prius Prime
    Are you sure its still the same for the current gen?
  8. Gokhan
    6,467
    2,582
    Paramount CA
    Yes, also for Gen 5, no JBL = no amplifier. JBL gets two extra speakers as well.
    https://www.toyota.com/priusprime/features/mpg_other_price/1235/1237/1239
    The following information is for Gen 4.
    (n ) "GreenEdge" Speakers (Models with Navigation System (JBL Premium Model))
    (1) "GreenEdge" speakers that efficiently convert electricity to sound with less sound corruption have been adopted. These
    speakers realize high sound pressure levels with low power consumption while still maintaining superb sound quality.
    (2) Due to the adoption of acoustic lenses, the directionality of the speaker output is improved, enhancing the area where the
    acoustics are effective.
    (o) Class D Amplifier (Models with Navigation System (JBL Premium Model))
    (1) The amplifier controls the power supplied to the amplifier circuit in the most efficient way according to the received audio
    signals.
    (2) The power consumption and heat generation of the Class D amplifier is small, minimizing the size of the heatsink and
    related parts. This realizes a compact and lightweight amplifier.
    (p) Clari-Fi Music Restoration Technology (Models with Navigation System (JBL Premium Model))
    (1) The amplifier utilizes Clari-Fi technology.
    (2) Files such as an MP3 or AAC have lost the audio details of the original music source during the file compression process. The
    Clari-Fi technology is used to restore the lost audio details and optimize data.
    (3) During playback of a compressed music file, the Clari-Fi technology improves the frequency characteristics, dynamic range,
    low frequency sounds, etc. of the music file in real time, recreating the wide soundstage of the original music source.
    These are the flimsy non-JBL speakers for Gen 4:
    These are the JBL speakers with an acoustic lens:
    #8 Gokhan, Sep 8, 2023
    otatrant likes this.
  9. Gokhan
    6,467
    2,582
    Paramount CA
    This is the Gen 5 Prius/Prius Prime JBL speaker system, which seems to be a carryover from the 2021 Yaris JBL speaker system. Part numbers could be different (86160-42170, 86150-42080, 86160-42200, 86150-K0010, and 86280-47120 for Gen 5 Prius/Prius Prime JBL), but they look identical.
    https://www.ebay.com/itm/385673005669
    #9 Gokhan, Sep 8, 2023
  10. Mksky
    Mksky Member
    61
    34
    Los Angeles
    2024 Prius
    Do you think we can install the JBL system after? plug and play?
  11. Gokhan
    6,467
    2,582
    Paramount CA
    How? The parts cost a fortune. If you want to go that route, I would recommend a different aftermarket system. They could even install a subwoofer in the trunk.
  12. Gokhan
    6,467
    2,582
    Paramount CA
    This guy thought the base audio was a D+ and the JBL audio was a C+. The ratings go up to A and then S+. So, the base audio is of below-average quality, and the JBL audio is of average quality. The reviewer was complaining that a $39k (Prius Prime XSE) or $43k (Prius Prime XSE Plus) car should get better audio.
    DM Sound—Prius—YouTube
    If you only care about the audio, an upgrade to the top trim may not be worth the cost. With JBL, you get an amplifier; so, it will definitely sound better especially if you adjust the equalizer, but the cost might not justify the upgrade.
    #12 Gokhan, Sep 8, 2023
  13. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    The Jbl doesn't have anything on most other premium audio systems, I was massively let down. However if you think your Bluetooth speaker sounds good you'll probably like it. I'm sure its better than the non jbl but still not worth the upcharge what so ever.
    douglasjre and aforkosh like this.
  14. Gokhan
    6,467
    2,582
    Paramount CA
    It helps a lot if you optimize the equalizer/loudness/fader settings on JBL.
  15. Preebee
    Preebee Senior Member
    867
    771
    Midwest
    2023 Prius
    I've been very pleased with the stock sound system. Nice upgrade over my G4. I'm sure the JBL system is superior, but I don't know by how much, or if it justifies upgrading the trim.
    After tuning the equalizer, I get VERY nice bass response and clarity when listening to your typical modern hip-hop fare.
    douglasjre likes this.
  16. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    It can help a little yes. I also upgraded the tweeters and added a sub which made it good enough for me for now. I plan to do some additional upgrades in the future. In reflection I wish I had just started with a base stereo.
    Gokhan likes this.
  17. Mksky
    Mksky Member
    61
    34
    Los Angeles
    2024 Prius
    I found this DSP Power Amp from BeatSonic Japan and coming to the US market soon. It has a version specially tuned for the 5th-generation Prius.
    Here is the website:
    http://www.beatsonic.co.jp/toon/
    車の音響が超進化。手軽に、音の臨場感が際立つ純正オーディオ良音キット「TOON」|マクアケ - アタラシイものや体験の応援購入サービス
    They had one for BRZ and GR86 here in the US market and here is the sound comparison video:
    I hope this can help the current sound system in the non-JBL Prius.
    Caleb2007 and Gokhan like this.
  18. Gokhan
    6,467
    2,582
    Paramount CA
    The professional reviewer gave the Gen 5 stock sound a D. If it were a nice upgrade over the Gen 4 stock sound, Gen 4 stock sound would be an F.
    I had the Gen 4 stock sound, and I have the Gen 4 JBL sound now, and I don't think Gen 4 stock sound was an F. I doubt there is much improvement from Gen 4 to Gen 5 in either stock sound or JBL sound after watching the professional review.
    #18 Gokhan, Sep 14, 2023
  19. Preebee
    867
    771
    Midwest
    2023 Prius
    Irrespective of any arbitrary grading systems applied, my opinion remains.
    A really good song to test a sound system's fidelity and punch is "You Should See Me in a Crown", by Billie Eilish. Playing that in my G5's stock system is surprisingly impressive, and has impressed passengers with better branded systems in their car.
    The G5 has more punch IMO. Yet the G4 wasn't horrible either. I just don't think it goes as loud and remains clear. Bass is better now also IMO. The G5 also has HD radio over my 2019 LE. That's not an insignificant upgrade.
    I guess it's important to point out I had a 2019. G4's extend to the 2022 year. Plenty of stereo improvements were likely made over those three years.
  20. Preebee
    867
    771
    Midwest
    2023 Prius
    This is interesting. Any direct links? Google translator isn't working perfectly.
    I wonder if the G5 installation is cleaner than the one demonstrated. I'd prefer not having to mount the amp under the seat.
