MPG Drop after EGR Clear
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by d4vit, Sep 13, 2023.
  1. d4vit
    d4vit Junior Member
    17
    GE
    Hello,
    i have this kind of problem on my Toyota Prius Gen 3 (2013) and i hope someone from this forum can help me because i've tried everything.
    My MPG got dropped by half when i had 40 mpg stable i did EGR/Throttle/Intake clear and my MPG dropped to 20-25 after that i have no errors no faults
    Heres things which i've done:
    • I've changed spark plugs
    • i've change air filter
    • i've checked battery's in service all are good
    • i've checked Upstream(Oxygen Sensor 1) and downstream (Oxygen Sensor 2 after cat.) live data on scan tool all is smooth and fine , perfect air/fuel ratio
    • i've changed engine oil
    • i've checked all wheels pressures
    but still no big change i only feel some little change when i start to drive without A/C but before EGR clear i was using A/C same as after EGR Clear but i had good MPG
    Magic Mark likes this.
  2. Magic Mark
    Magic Mark New Member
    I'm wondering if a gasket is leaking on one of the components you cleaned? I'm trying to think of a hose that might not have been missed or something that wouldn't throw a code.
    Danno5060 likes this.
  3. JC91006
    JC91006 Senior Member
    16,768
    8,565
    That is a drastic drop in MPG. What type of plugs did you put in? Ones you bought from the dealer and not ebay right?
  4. d4vit
    d4vit Junior Member
    17
    GE
    Yes but as i said i did spark changes after mpg drop after egr service before all worked like a clock
  5. d4vit
    d4vit Junior Member
    17
    GE
    I also thinked that egr got dead but i should get at least fault code on diagnostic but i dont get it and tbh that is the only one thing which i didnt checked but i think i would get some changes or noice or error code but no all is clean
  6. d4vit
    d4vit Junior Member
    17
    GE
    so no one can help me on so big forum? :(
  7. Mendel Leisk
    41,440
    Where’s “GE”? Are you in the United States of America? Or? Are there Toyota Dealerships nearby?
  8. d4vit
    d4vit Junior Member
    17
    GE
    i'ts country Georgia we dont have official Dealership of toyota here
  9. JC91006
    16,768
    8,565
    I would suspect your brakes are somehow involved in the lowered MPG. It could be possible your brakes slide pins are stuck (possibly due to lack of lubrication) or your calipers are no releasing the brake pads.
    Weak batteries or engine issues would not account for that drastic of mpg drop
  10. Mendel Leisk
    41,440
    What’s the miles (or kilometres)?
  11. Mr. F
    Mr. F Active Member
    388
    257
    Washington
    Is the 20-25 MPG reading over a short drive or over a longer period of time? Any misfires at all?
  12. d4vit
    d4vit Junior Member
    17
    GE
    no missfires at all, cant go more than 40 MPG i have range in between 35-40 MPG with long drive
    measured compressions in cylinders and i have 12.5 Bar in each im thinking it can be Spark plugs, but i receive 0 obd code
  13. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    181
    US
    @d4vit Did you Disconnect your 12v Battery before doing the EGR Cleaning?
  14. Mendel Leisk
    41,440
    Again, what’s the miles?
  15. d4vit
    d4vit Junior Member
    17
    GE
    I'm back with the same problem so far. I am once again fighting to fix the low MPG issue. I'm not sure if it's EGR-related yet, but here’s what I’ve done so far:
    • Tried changing the ECU
    • Replaced spark plugs with OEM Denso
    • Measured compression (I have 11.5 on each cylinder)
    • Changed injectors
    • Tested the 12V system: it's holding 12V when the car is off and 14V when the car is on
    • Replaced the MAF sensor
    • No DTC available at all car is super clean on OBD2 diagnostics
  16. Mendel Leisk
    41,440
    What's the miles?
  17. d4vit
    d4vit Junior Member
    17
    GE
    170k
  18. d4vit
    d4vit Junior Member
    17
    GE
    0g of oil leak
    All piston compressions are good
    Sevice being done every 6-8 months
  19. Mendel Leisk
    41,440
    How recent was the EGR cleaning? Anything specific prompt you to do it?
    With 170K miles, and presumably EGR only recently cleaned, I'd suspect head gasket failure
  20. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    #20 MAX2, Sep 25, 2024
