2013 Prius IV corroded bus bars - HELP!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ZL86, Sep 16, 2023.
  1. ZL86
    ZL86 New Member
    New York
    Hi all, recently received a "Hybrid Battery System Failure" Alert on my vehicle which has about 70,000 miles on it.
    took it to the dealer for the $350 diagnostic and got a P0B51 error code "hybrid battery voltage sensor "E" circuit low". I am not entirely sure what happened, but next thing i know they are telling me i have a new $1000 charge to fix the voltage sensor. Final straw, they now want to replace the entire battery assembly for $4500, because the bus bars are corroded and that the battery warranty will not cover the repairs.
    Should i keep fighting to get it replaced under warranty (10 years/150,000 mile which toyota recently upgraded from 8yr/100,000miles) - since i believe it is a result of galvanic interaction b/n the copper bus bars and the stainless steel nuts and likely presence of battery fluid BUT they are saying is water damage? should i just tell them to replace existing battery as is and clean the corrosion from the busbars and sensor arrays myself/ at my local shop for time? OR should I bite the bullet and replace the battery?
    any and all advice welcome i included photos of the corrosion.
    51,884
    Are they agreeing that the battery is under warranty?
  3. bisco
    51,884
    If so, you need to call Toyota corporate customer service
  4. ZL86
    ZL86 New Member
    New York
    no not yet. i am still trying to get them to agree. toyota corporate is BS and cant put me in contact with the corporate warrantee center as only dealerships can do that. dealership wont give me adequate info on why the claim was rejected
  5. bisco
    51,884
    what's the in service date (registration)
  6. AzusaPrius
    AzusaPrius Senior Member
    2,180
    919
    My guess is that they can tell it is not original, because there should not be any black marker on any module.
    Worst case just buy yourself a new bus bar kit from AcenBay.com and use promo code "azusa" to save some money.
    Then once the new bars are installed, check the battery with the Dr. Prius App.
    Depending on your available funds you can source OEM modules and replace the bad ones you have.
    There is also the best option and that is to upgrade your prius with a Lithium HV battery from here.
    https://projectlithium.com/?ref=mG0GE
    waiting until after October will give you the latest modules which have better air flow.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    You are 100% incorrect with this statement. Anyone who works on these batteries will tell you the factory OEM modules frequently have marks on them like this.
    And for the OP, that corrosion on the sensing wires/tabs is 100% not from water damage. That is the exact corrosion seen on just about every single OEM battery after a few years of use. It's nothing unexpected. You may want to check the plug/socket on the voltage sensing module. It will often have corrosion buildup on the pins, which will cause codes.
  8. William11348o
    William11348o Junior Member
    57
    Hawaii
    Agree with TMR-JWAP my battery has similar corrosion on bus bars and I know it didnt get wet. Mine isnt as bad but environment can be the cause, moisture in the air, etc. So are bus bars not part of the battery?
  9. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    If there's a defect with anything contained inside the battery case, and it's within the warranty time/miles requirement, the battery replacement should be taken care of under the car's warranty. If the case was opened by the car owner prior to Toyota diagnosis, broken seals may or may not affect warranty claims. Sometimes those flimsy plastic film tamper seals crack and split on their own after several years.
    #9 TMR-JWAP, Sep 20, 2023
  10. William11348o
    57
    Hawaii
    Question. When I connected my battery charging cable I didn't see any seals or remnants. The car was supposedly only serviced by Toyota. Wouldnt they replace the seals? Or maybe they fell off? Or the seller lied to me? Battery appears to be original. Would like to know the truth.
  11. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    What battery charging cable are you talking about? Can you explain further?
    Typically, if the HV battery has seals, they are a piece of green plastic tape about 2-3 inches long and about an inch wide. I don't think all Gen 3 models have it. Definitely Gen 2, tho.
    I may not be accurate on this, since I'm more of a Gen 2 person, but I'm pretty sure the Circuit E code you got is referring to Block 5 of the HV battery. Whether it be the sensor wire, the voltage sense ecu, or the module itself, it should be covered under warranty. I may be wrong....wouldn't be the first time.
    You can look at the serial numbers on the top of the modules to get the manufacture date. They should be very close in sequence also. If you find some that are way off, then battery is not original. The date codes should be within a couple months of the car build date.
  12. William11348o
    57
    Hawaii
    I have the Maxx Volts EL-1. Perhaps i should say 'harness'
  13. Mendel Leisk
    41,386
    Could the seals in question be those orange plastic caps that need to be unscrewed with the tip of the safety switch?
  14. William11348o
    57
    Hawaii
    Maybe but they are replaceable and arent deterants like the tape seals. WDIK
