Here's my NEW 2023 Prius LE (with aftermarket wheels)
Discussion in 'Gen 5 Prius Main Forum' started by Argyros, Sep 14, 2023.
  1. Preebee
    Preebee Senior Member
    867
    771
    Midwest
    2023 Prius
    From a distance, I really think the LE hubcaps look cool - kind of futuristically mean even. The closer you get the less their appeal. But they've grown on me now, it wouldn't be worth it to me to change at this point.
    I will say this, my VERY first impression of the wheels up close was quite negative. But we are amazingly adaptable creatures.
    It really wasn't that hard... ;)
    Blizzard_Persona and reallyreal like this.
  2. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    What did the disclaimer actually say?
  3. Tamadrummer88
    Tamadrummer88 New Member
    Austin, TX
    There is no long term or short term benefit to doing a “break in” oil change.
  4. RRxing
    RRxing Senior Member
    2,553
    1,826
    NEPA
    Cheap enough insurance...
  5. Trollbait
    12,652
    Against what? We are long past the days where engine break in entailed the engine self machining parts to mating.
  6. Preebee
    867
    771
    Midwest
    2023 Prius
    Particularly with Japanese cars. Their tolerances are legendary.
  7. 23PriLE
    23PriLE Member
    95
    67
    North Central Florida
    2023 Prius
    I wasn't sure I'd like them either but I think they make the car look more aggressive. They also work well with silver. My previous car, a 2008 Civic Coupe, was also silver but the Cutting Edge is considerably darker than the silver Honda used on the Civic and I think that's a factor too.
    Black wheel covers must be a trend as I recently saw a Tesla that had them too. Theirs didn't look as good, IMO.
    Owners who don't like black and don't want to spend the $$$ on new wheels can always paint them. The stock wheels used on the LE look nice without the covers too but I suspect you'd lose a bit of mpg on the highway.
    After I've had a car for a while I don't spend much time looking at the exterior styling and I couldn't care less whether other people like it or not. Wheels have never been a priority for me but I realize that for many people they are - especially people who post on car forums.
    Preebee likes this.
  8. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    Here's a better picture of the aftermarket wheels- they look much better and can see them more clearly from this angle!
    daisy555, Ragman777, Gokhan and 2 others like this.
  9. Bobo99
    Bobo99 Junior Member
    33
    London ON
    2023 Prius Prime
    Since we're talking about wheels here, does anyone else find the lug bolts to be a turn-off? I prefer to do my own tire rotation and winter/summer swap, so for me the bolts are a huge drawback. Apparently it's possible to install an after-market stud/lug nut kit; I'll have to look into that. What's the recommended torque for tightening the 2023 PP lugs?
  10. Bobo99
    33
    London ON
    2023 Prius Prime
    So for the plug-in, I assume that this translates into 1,000 miles driven in HV mode, because if driven in EV mode that would be irrelevant.
  11. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Have you confirmed that your PP actually has lug bolts? I'm just asking because my Prius HEV has lug nuts.
  12. Bobo99
    33
    London ON
    2023 Prius Prime
    My Prius right now is just a twinkle in the eyes of the production scheduler in Japan. I was just going off of what the Car Care Nut was showing in his 2023 Prius introductory video, and I took it as a given. He was showing a pre-production vehicle, so I'm hoping that Toyota came back to its senses and reverted back to studs and nuts. Glad to hear that this is actually a possibility.
  13. Mendel Leisk
    41,820
    I had an opportunity to weigh 15" Corolla steel rims, and 15" Plug-In Prius alloy rims. Pretty close:
    15" Plug-In Prius alloy rims: 18.17 lbs
    15" Corolla steel rims: 18.32 lbs
    Preebee likes this.
  14. Trollbait
    12,652
    After what happened with the bZ4X release, it appears Toyota delayed the switch with other models.
    Bobo99 likes this.
  15. JeffHastings
    JeffHastings Member
    223
    79
    Whippany, NJ
    Good luck with those; they do look great. I'm of a different mindset; I think the standard wheels look fine but that's not an important factor for me. I would insist on keeping 17" wheels for better MPG in any case. As an aside, to show how differently I think, I bought a 1997 Ford Taurus G in 1997 which had optional aluminum wheels added to it. They looked fantastic but I had the dealer remove them to save me $1300. $1300. was relatively chicken feed even then but I didn't care. I didn't need those fancy wheels and I was happy to save the $1300. But I think you made the right choice for yourself; they do look terrific!
  16. Argyros
    275
    142
    2023 Prius
    Jeff, these are also 17" wheels, and I think at most I might have lost 1 mpg with them. Asthetics wins out here :). Thanks for your kudos!
  17. JeffHastings
    JeffHastings Member
    223
    79
    Whippany, NJ
    It's your car and your choice and again, it looks great. I'm just too frugal to indulge myself this way; perfect example, my 1997 Ford Taurus.
    Argyros likes this.
  18. Argyros
    275
    142
    2023 Prius
    My aftermarket Wheels came with new locking lug nuts and a matching lug wrench.
    Bobo99 likes this.
  19. daisy555
    daisy555 Senior Member
    1,727
    715
    CT
    So you get the oil changed right away after buying it?
  20. daisy555
    1,727
    715
    CT
    Nice!!
