Hybrid Battery replacement Gen 2 suggestions?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusrust, Sep 23, 2023.
  1. priusrust
    priusrust Member
    216
    79
    MA
    Hello
    1. technical question: how long can you run on a completely bad hybrid battery?(triangle on) Will it just it just rely on the ICE and give you bad mileage, but not harm anything?
    2. looking for CHEAP replacement hybrid battery....them doing install. Looked at Greenbean, now leaning Greentec. (because cheaper) Looking for minimum 1 year guarantee.
    Thanks!!!
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    A completely bad hybrid battery will stop you DEAD.......because it is the HV
    battery that STARTS the engine.
    And good luck with "cheap".
    That often ends up being MORE expensive and
    a huge PITA.
    priusrust and Brian1954 like this.
  3. bisco
    52,294
    there's no telling how long. could be quite awhile, or tomorrow. it just depends on how bad the modules are.
    greenbean seems to get the best reviews, but it is a very low bar, and you have to be prepared for trouble and downtime if you're one of the unfortunate ones.
    check reviews here and elsewhere before making a decision
    priusrust likes this.
  4. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    Are you planning to only keep your car for 1 year? If so, then this sounds like a plan.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    But not a GOOD one, maybe.
    Others who have opted to go the cheap route have found that they
    need to exercise the "warranty" several times within a year.
    JohnPrius3005 and priusrust like this.
  6. priusrust
    priusrust Member
    216
    79
    MA
    So....other option is to have an OEM installed. I've heard they have come down to $2000...I'll call dealer tomorrow. Lot of factors in flux: if I plan to keep car more than 1 year, etc. Facing classic older car issue: dumped enough $ in (recent brake actuator, wheel bearings, radiator, CAT shield) ...where I'm inclined to dump more in, and figure it should be trouble free for a spell. The oil usage on this 2004 -160k miles- is amazing! Never need to add any.....though I give it 'sips'. More reason to keep it. If I do, I'll likely opt for OEM (if 2G)...if not $1000 Greentec route. (warranty is transferable) thanks for input!
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    Well that's not necessarily a good sign either.
    Have you checked your coolant level lately ??
    A head gasket leak might be letting WATER into the crankcase.
  8. Brian1954
    2,371
    954
    Yes, some dealerships sell the HV battery for $2000 from their parts department plus a $1350 core charge which you get back when you return the old OEM battery. You will need to install it yourself or pay an independent garage to install it. I am guessing that you will receive a quote from the dealership of about $3500 for the battery and installation. Installation is not very difficult. There are many you tube videos.
  9. priusrust
    priusrust Member
    216
    79
    MA
    Sorry, maybe I was unclear. Meant to say never need to add oil......good thing
  10. priusrust
    priusrust Member
    216
    79
    MA
    Good estimate. Called dealer: $1,950- for battery + $1100 or so for labor to install. They will not sell battery w/o install. Even if I could buy OEM battery w/o install, I'm not in a position to install myself. So.....leaning Greentecauto. $995 for battery inc/ install. 1 yr warranty
  11. sam spade 2
    7,035
    2,804
    2017 Prius c
    No you were absolutely clear.
    Maybe I wasn't.
    Maybe the level of oil on your dipstick never gets to the LOW mark because
    your lost oil is being replaced by coolant leaking into the crankcase through
    a leak in the head gasket.
    Clear now ??
  12. priusrust
    priusrust Member
    216
    79
    MA
    crystal***(y)
    ok, so that is not the case. Coolant not being mysteriously depleted, and oil not milky color. Oil level does slightly dip between oil changes, but very slightly....pretty amazing for a 2004....esp when I hear of excessive oil usage common problem.
