Third day with new car, dead 12V battery, second day in a row :(
Discussion in 'Gen 5 Prius Main Forum' started by mountaineer, Jul 30, 2023.
Tags:
  1. Gokhan
    Gokhan Senior Member
    4,619
    1,855
    Paramount CA
    I will take the plug-in functionality over a lower trunk deck any day. It also makes it easier to load and unload objects. ;)
  2. Louis19
    Louis19 Active Member
    378
    338
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Hey ,,,you are at the right place on this board . Being a new member with your first PHEV i understand that learning curve looks like a daunting task but the vast majority of members here are very helpfull and really know a bunch of informations on Hybrids , Plug in hybrids , and Electric vehicules ..so welcome aboard and Enjoy your new car ,,,and also Priuschat
  3. flim
    flim Active Member
    206
    139
    Huntington Beach, California
    2023 Prius Prime
    XSE Premium
    I still have my 2012 Prius Plug-In and never had any issues with my 12V battery.
    Just replaced the original 12v battery recently after 11 years! It wasn't a coincidence that the battery finally died after I stopped driving the PIP when I got my Gen 5 Prius Prime last May.
    bisco, Louis19 and Gokhan like this.
  4. Gokhan
    4,619
    1,855
    Paramount CA
    What brand was the OEM battery?
  5. bisco
    49,397
    I can’t believe you’ve been a member since 2008, there are are lots of pips, and were a lot more back in the day.
    But like any older car, they are being replaced by newer vehicles, especially ev’s, as I hope to be doing soon
    Trollbait likes this.
  6. Trollbait
    11,513
    There have been other reports of the 12V in some Toyota hybrids dying for 'no reason'. Someone was once looking for help with an Auris hybrid. As stated, hybrid batteries are lower capacity. Maybe Toyota cut it too close with the battery size vs the vampire drain. One of those systems causing the drain could be out of spec, like something not going to sleep when the car powers down. A key fob stored nearby might be enough to keep the SKS awake. Really hard to pin such causes down.
    Bad 12V batteries also happen. Though, I think those are easy to rule out.
    The reddit poster should have gotten a new 12V. Repeated drainings to 'dead' shorten the battery's life, and that could be the cause of future incidences.
    Not when it's a heavy or large object on a flatbed cart.
    The gen4 Prime loses over 6 cubic feet of cargo space to the battery. It lost more space than in the C-max Energi did. A PHEV made from a model that wasn't even designed to be a hybrid, and came out 6 years earlier. The best that can said about the Prime battery mounting is that it is a cleanly done after market conversion.
  7. Louis19
    378
    338
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Indeed , in an other matter ,they redesigned the hatch using carbon fiber and the looks front an back to mark a difference between the hybrid model.
  8. Gokhan
    4,619
    1,855
    Paramount CA
    Yeah, but I've seen very few on the roads. I recognize one when I see the silver bumper cover.
    My rich ex-landlord used to have one, and he later traded it in for a Tesla Model S when that came.
    On the other hand, there are many Gen 4 Prius Prime PHEVs on the road. So, statistically, you will have more people complaining about Gen 4 PHEV 12-V battery problems.
    Moreover, as I said, I left my Gen 4 Prius Prime PHEV 12-V battery uncharged for six weeks this summer and had no issues. I am convinced that the problem is with the owners not using their cars properly.
  9. bisco
    49,397
    i won't try to unconvince you :)
  10. Gokhan
    4,619
    1,855
    Paramount CA
    See me in ten years when my original OEM battery is still as good as new. ;)
    Gen 4 Prius Prime actually has a lot of 12-V battery protection measures. It monitors the temperature, voltage, current, and SOC of the 12-V battery using a dedicated battery sensor to prolong its life. It is the owners who are the problem. ;)
  11. bisco
    49,397
    not giving up eh? oh well, i'm not gonna find the threads for you, no owner issues. maybe they fixed the problem by 2021
  12. flim
    flim Active Member
    206
    139
    2023 Prius Prime
    XSE Premium
    GS Yuasa
    Gokhan likes this.
  13. Gokhan
    4,619
    1,855
    Paramount CA
    Yes, I've seen all those threads. I am an owner, too. There are no such issues if you know how to use your car, and contrarily, if you don't know how to use your car, you will drain the 12-V battery in a blink of an eye in any modern PHEV or BEV.
  14. bisco
    49,397
    Isn’t it odd that pip owners knew how to operate their cars and prime owners didn’t
  15. Mendel Leisk
    38,653
    The name changed everything. Plug-In Prius was sensible/succinct; Prius Prime, just saying that, you feel like you're buying into the Toyota PR machine.
    Louis19 likes this.
  16. Trollbait
    11,513
    Does that mean people buying the Prius PHV overseas better knew how to operate their car than those buying the Prime?
  17. Louis19
    378
    338
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Yes indeed ! .... how about Beyond Zero badge;)
    #57 Louis19, Sep 24, 2023
  18. Gokhan
    4,619
    1,855
    Paramount CA
    It is simple physics. 12-V batteries don't go bad if they are properly recharged. Gen 3 Prius Prime is well-equipped to do that.
    However, Gen 3 Prius Prime is a much more sophisticated car than the Gen 2 Prius PHEV, which means a much higher drain for the 12-V battery. That in turn means that it tolerates abuse by the owner (sitting in the car with the car not in the ready mode, only doing short trips, etc.) much less.
  19. Louis19
    378
    338
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Interresting remarks , i am lost as to Prius prime ...what is a gen 3 Prius prime :(
    bisco and Gokhan like this.
  20. Gokhan
    4,619
    1,855
    Paramount CA
    I refer to the 2017–2022 Prius Prime PHEV as Gen 3, despite it being the second PHEV generation.
    Louis19 likes this.
