Michelin Primacy tires failing !!!
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by rkalbo, Sep 24, 2023.
  1. rkalbo
    rkalbo 2024 XLE
    85
    Huntingburg,IN 47542
    2023 Prius Prime
    #1 rkalbo, Sep 24, 2023
  2. Mendel Leisk
    41,824
    I got a set of Primacy MXM4 (in 215/45R17)about 3 years and 15k kms back, seem to be wearing fine. Really dropped mpg at the outset, though not bad now.
    #2 Mendel Leisk, Sep 24, 2023
  3. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    I don't believe that overall, there is a "safety" issue with the Primacy tires. It's more likely an owner issue of proper maintenance and/or use of their vehicle, proper inflation, and age of the tire. The Primacy line are OE tires on many SUVs and trucks, but it's just a street tire and not meant for any type of heavier duty work. It's generally recommended that tires should be replaced after 6-7 years regardless of how many miles are on the tire. Years ago, Ford and Firestone were sued due to tires catastrophically failing on their Ford Explorers. Even though there was a large settlement, the issue really was about Ford dealers recommending inflating the tires with only 24-26 lbs to give the impression of a softer ride. The old Explorers had the twin I-Beam front suspension while robust, made it ride like a truck.
  4. KMO
    KMO Senior Member
    2,004
    729
    Finland
    2023 Prius Prime
    You seem to have found a year-old bot-generated page created from 5 Reddit posts spanning 15 years.
  5. rkalbo
    rkalbo 2024 XLE
    85
    2023 Prius Prime
    Poor tread life, followed by blowout.
    Submitted 1 month ago
    By Joe 2023
    From undisclosed
    Verified Reviewer
    Reviewed at
    Very concerned with the number of blowouts reported here. My wife was driving in our neighborhood (just left the house) and had a blowout on front passenger side. Thankfully she was only going ~25mph and was able to limp the car back to the driveway. How does a Michelin tire blow out at 42K miles going ~25 mph? Tire pressure was set at 35lbs as required. I expected much more from the premium tire brand. Is there something defective with this tire?
    Bottom Line No, I would not recommend to a friend
    Was this review helpful to you?
  6. Mendel Leisk
    41,824
    Took a look at my records: ours went on in March of 2019, at ~80K kms, currently around 99K kms. They are off the car through winter (replaced by snow tires). Not a lot miles granted. They look good, no signs of cracking. Feel good. Tread depth currently 8/32" which is wearing kinda fast.
