2023 Prius as a work car need a lift in the rear.
Discussion in 'Gen 5 Prius Accessories and Modifications' started by BenzYoc, Sep 24, 2023.
Tags:
  1. BenzYoc
    BenzYoc New Member
    Near you
    2023 Prius
    Limited AWD-e
    We got a 2023 Prius AWD as a new work vehicle.The rear will have a hitch with a box that weighs about 85-95lbs. Both the box and hitch will weigh about 130lbs. When we added 130lbs to the rear the back sags about 3/4 of a inch.
    What options do we have to stop the sagging in the rear?The Prius will have the box attached for its entire life.
    Unfortunately we do not have a hitch yet they are not available until mid November.
  2. lohikaarme
    lohikaarme Active Member
    337
    338
    NY
    2023 Prius
    Limited AWD-e
    Maybe I am remembering incorrectly but doesn't the manual say no hitch?
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,501
    Taylors, SC
    The warning is about towing a trailer. A trailer hitch for a bike rack or bicycle carrier is obviously OK.
  4. Mendel Leisk
    41,921
    Still, an installed hitch may be problematic if you’re ever making a warranty claim: hard to prove you didn’t tow an enormous boat, day in, day out. And knowing Toyota, I suspect they’d say even something like a wiper motor or door lock mechanism was effected by towing, lol.
    douglasjre likes this.
  5. BenzYoc
    BenzYoc New Member
    Near you
    2023 Prius
    Limited AWD-e
    The hitch will only be for a tote. It will never "tow" anything. The weight of the tote is 130lbs including the hitch.
  6. BenzYoc
    BenzYoc New Member
    Near you
    2023 Prius
    Limited AWD-e
    aluminum tool box 28 lbs
    tote 35lbs- I can lighten this a little bit.
    hitch-35lbs
    Contents of tool box- 20-30 lbs.
    total-no more than 130lbs.
    I was considering removing the back seats to save weight on the rear.
  7. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    You're going to need a custom spring or airbag to make that work.
  8. Georgina Rudkus
    3,513
    2,501
    Taylors, SC
    Even with the long lever arm, with no passengers in the back seat. the car should be fine as is.
  9. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Wouldn't folding the rear seats down give you enough space for hauling your gear?
  10. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    These fit turd gems (3rd gens). Measure to see if same for yours
    FIRESTONE 4136 Suspension Leveling Kit https://a.co/d/7fQB1kS
    otatrant likes this.
  11. douglasjre
    2,205
    736
    Null, NL
    Take the back seats out and put a piece of plywood. You'll have more cargo room. You'll be able to keep your load out of the weather and keep it from rocking as well. You don't want that much weight that far behind the rear wheels it can make the tail wag and you'll lose control the vehicle.
  12. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Is there some GOOD reason that your tools and supplies can't go
    into THAT space, instead of screwing around with the rear mount ??
  13. Jim Stoll
    Jim Stoll Member
    75
    45
    NC
    2023 Prius
    LE AWD-e
    HacksawMark likes this.
  14. BenzYoc
    BenzYoc New Member
    Near you
    2023 Prius
    Limited AWD-e
    I wanted to update this posting. The car is going to be used for pest control. I scrapped the box idea and got approval to make a partition. It needs to have a air tight partition separating the passengers from any chemical storage.
    Its not prefect but its air tight and I added a vent. What i did was slightly modify the Styrofoam and add a layer of 3/4 inch plywood below the rubber prius mat.. For the "wall" I used 1/2 plywood with a moisture barrier than used silicone and foam to fill gaps. We could have trimmed the foam to give it a cleaner look but it wasn't need.
    I tested the barrier with compressed air and sealed a few open areas. After my first test run working with the car I got 47mpg. Thats up from 17mpg using my full size work truck. Next time ill drive nice ill be over 50mpg.
    Thanks for all the ideas and help.
  15. Georgina Rudkus
    3,513
    2,501
    Taylors, SC
    There ar cabin exit vents that go to the rear quarter panels through the entire car from the hvac system. You will have to vent the cabin in some way before the partition to prevent back pressure in the cabin.
  16. BenzYoc
    BenzYoc New Member
    Near you
    2023 Prius
    Limited AWD-e
    Impossible to tell from the pics but I actually cut the rear fabric/paneling right along the partition to bear metal and used 4 inches of foam. Basically The rear it totally independent of the cabin. I even pulled back the head liner and added a barrier to be extra safe.
    The hardest part has been the seat belts for the back seats. But i figured it out.
