2023 Prius Prime doors unlock after charging?
Discussion in 'Gen 5 Prius Technical Discussion' started by Harry94025, Jul 26, 2023.
  1. Harry94025
    Harry94025 New Member
    Castro Valley
    2023 Prius Prime
    XSE
    Just charged my new Prius Prime (using supplied 120 vac charger) and for the second time the Toyota app tells me the charging is complete, followed in a couple minutes, “all doors are unlocked”. Then I lock the doors with the app and all is ok again. Apparently this has been an issue with other Toyota PHEVs like the RAV4.
    Anyone else having this problem?
    Harry
  2. Numtini
    Numtini Member
    91
    93
    Cape Schrod
    2023 Prius Prime
    XSE
    Are they actually unlocked? The app sometimes "lags" behind reality.
  3. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    351
    272
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    What is your locking policy set for?
    When mine was at the default lock-lock, and started charging with the doors unlocked, the app would tell me the doors were locked but they were not.
    I have found the app to be untrustworthy and often the notifications are delayed significantly or flat out wrong.
  4. Harry94025
    Castro Valley
    2023 Prius Prime
    XSE
    Yes, the doors are unlocked. I opened the driver’s door and didn’t have the key with me. Interestingly, the charger plug is not released, expect after I locked and unlocked the doors with the key. It would appear the programming is confused about the door and charging plug functions.
    tovli likes this.
  5. Wind23
    Wind23 Junior Member
    I think I am getting the same problem, the car just automatically unlocked all doors.
  6. Nntw
    Nntw Active Member
    398
    248
    Toronto
    2023 Prius Prime
  7. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    That should be an option in settings on the primes touchscreen. I remember seeing it the first couple days I had the car when I was scrolling through everything and made sure it was on lock.
    I guess a scenario where you would potentially want it to unlock after a full charge would be if you’re parked in a secure garage in your house and it’s one less step to unlock the car getting in to leave for work just unplug and go... Lol.
  8. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
  9. JessieD
    JessieD New Member
    2023 Prius Prime
    SE
    I've searched throughthe touch screen and the app (the app basically has nothing except remote lock/unlock and remote start which never works), and I can't figure out how to turn off the auto-unlock at charging complete feature. Halp!
