2023 Prius Reviews
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Dec 14, 2022.
  1. tmorrowus
    tmorrowus Member
    514
    Here's my mini review of the 2023 Prime SE trim:
    The biggest thing I miss is smart key for hatch and passenger door. After having gotten used to hatch smart key on my previous car, it is taking some effort to relearn to dig the remote out of my pocket to unlock the hatch.
    This also affects charging since you have to unlock the doors to unlock the charger cord from the car. If I had SKS on the hatch, it would be easier to unlock the nearby charge port by pressing the hatch button than digging the keys out of my pocket or walking around to the other side of the car to unlock the driver door.
    The seats in the SE don't feel as supportive as I'm used to, but I haven't had a chance to drive the higher trims to compare.
    There is much less headroom than my old 2004 Prius for tall people like myself (6'). I barely fit, but I have to duck my head awkwardly to get in, even with the seat all the way down. If I style my hair up, it rubs the headliner. The grab handle above the door is right next to my head, raising concerns that I could bump it with my head on rough roads. I couldn't comfortably ride in the back seat.
    I thought I would miss the 360 camera, but with parking sensors all over the bumpers it is much less of a concern than I would have thought.
    As an audiophile the basic sound system is very lacking for music, so I plan to upgrade it with a custom system. It's fine if you just listen to podcasts or news.
    The headlights have to be turned off manually when you get out of the car, or else you will get a loud warning tone. This is probably a good thing since it forces you to choose between DRL and night headlights when you start the car up. But in retrospect, the headlights that can stay in auto position (and automatically switch between off, DRL, night) on the higher trims would have been nice.
    Overall, I'm very happy with the Prime SE.
  2. Preebee
    Preebee Senior Member
    867
    771
    Midwest
    2023 Prius
    Have you tweaked the equalizer a bit? It makes a helluva difference!
    I was listening to a song the other day and decided to crank the basic system higher than I ever have before, just to see if it would distort. It went REALLY loud. And I could feel the bass in my chest. This is much better than the G4 system, and I would say comparable to the JBL I had in my Mazda maybe 7 years back.
    Definitely not a thousand dollar custom rig, but a long way from just good for the "news" IMO.
    Teleplayer and Blizzard_Persona like this.
  3. Gokhan
    Gokhan Senior Member
    6,467
    2,582
    Paramount CA
    Hmm, the cord can't be pulled out without unlocking the car but with the remote in your pocket? That's really strange.
    I am pretty sure that all Prius trims have auto-off lights, but only the higher trims have auto-on lights. You can also change the settings so that the lights immediately turn off when you open the door.
  4. otatrant
    otatrant Active Member
    348
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
  5. Teleplayer
    Teleplayer New Member
    26
    17
    Northeast US
    2023 Prius
    I have to wonder if all the comments about the base system sounding "tinny" are posted by owners who have no idea what EQ even is or how to find it in the settings. Only the very best component systems are going to sound optimal with flat or nearly flat settings. Virtually every base factory system - or even premium factory systems - are going to need some kind of EQ adjustment.
    I don't do critical listening in the car so count me among those who wouldn't see the value in spending $1000+ (or more) for a high end system for my vehicle. I haven't checked out Prius yet other than to just sit in one but I'm encouraged to hear that the base stereo is at least serviceable. Looking forward to hearing it, and I hope it's not as bad as some of the reviewers have stated.
    Preebee likes this.
  6. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    2023 LE trim doesn't have auto off lights- only when you have it in daytime running lights will they turn off; otherwise, when the headlights are on, you have to turn them off with the car.
  7. Gokhan
    6,467
    2,582
    Paramount CA
    That is not correct according both the specs on the Toyota website and owner's manual. As I said, you can also change the vehicle settings to select when the light turn off.
    ■Automatic light off system
    ●When the headlights are on: The lights turn off 30 seconds after the power switch is turned to OFF and a door is opened and closed. (The lights turn off immediately if LOCK on the key is pressed after all the doors are closed.)
    ●When only the tail lights are on: The tail lights turn off automatically if the power switch is turned to OFF and the driver’s door is opened.
    To turn the lights on again, turn the power switch to ON, or turn the light switch to the OFF, DRL OFF, or AUTO position once and then back to the taillight or headlight position.
  8. Gokhan
    6,467
    2,582
    Paramount CA
    A really good review, which also shows underneath the car.
    JoeBlack likes this.
  9. Preebee
    867
    771
    Midwest
    2023 Prius
    JBL vs standard sound | Page 2 | PriusChat
    Here's a thread where we talk more about it. I also include a photo of my EQ settings. Roll those windows up and crank one of the test songs I mention, and I think you'll be more than pleased. ;)
    Teleplayer likes this.
  10. Argyros
    275
    142
    2023 Prius
    Here's something that will take one of your items off the list- I have an LE, and I set all the doors to open when I unlock; so now, when either I touch the door, or unlock with the keyfob, all doors plus the hatch open! Surprised me, but it works!
    Preebee and Gokhan like this.
  11. Nntw
    Nntw Active Member
    398
    248
    Toronto
    2023 Prius Prime
    2023 Toyota Prius Review: The Hero Hybrid We Need Right Now (thedrive.com)
    You’ve seen the ads: “2023 Toyota Prius. It’s (insert mildly interesting adjective) now.” And, credit where credit’s due: the all-new, fifth-generation Prius is incredibly stylish. But here’s the thing: I’m not sure modern-day Prius buyers care very much about being chic. The early adopters have already bought EVs—or will soon—and the rest of us are sitting on the sidelines, waiting to see what happens next. That leaves hybrids as the choice for pragmatists who want to go further on a gallon of gas without changing their lifestyles. In the electrification landscape of 2023, the Prius is a compromiser’s car—and there’s nothing sexy about compromise, at least in theory.
    The Prius’ value is, now more than ever, in its practical attributes, and those attributes had better be damn good. So, rather than focusing on its newfound curb appeal, I set out to answer the more important questions: Is it better at the things a Prius should be good at? Is it a more useful and frugal daily driver? And, yes, is it something a self-avowed car enthusiast wouldn’t mind living with? After driving a 2023 Prius Limited for a week and nearly 700 miles, I’ll spare you the suspense: it’s still the hybrid GOAT, and its unique mix of value, style, and competence means it’ll appeal to a broader swath of people than ever before.
    2023 Toyota Prius Specs
    Base Price (Limited as tested) $34,465 ($37,494)
    Powertrain 2.0-liter inline-four with a permanent magnet AC synchronous motor | 222-volt lithium-ion battery | continuously variable automatic transmission | front-wheel drive
    Horsepower 194 @ 6,000 rpm
    Torque 139 lb-ft @ 4,400 rpm
    Curb Weight 3,164 pounds
    Seating Capacity 5
    Cargo Volume 20.3 cubic feet
    EPA Fuel Economy 52 mpg city | 52 highway | 52 combined
    Quick Take With hybrids this good, it’s hard to justify buying an EV just yet.
    Score 9/10
    The Basics
    The 2023 Prius takes Toyota’s OG hybrid formula into its fifth generation, and in Toyota’s current lineup, it fits between the cheaper Corolla Hybrid and larger Camry Hybrid models. It wears entirely new sheetmetal over the existing TNGA-C platform that also underpins the Corolla and Corolla Cross, as well as the Lexus UX and the outgoing Prius. As a sedan in an SUV world, the Prius indirectly competes with its siblings, the Corolla Cross Hybrid and RAV4 Hybrid, but Toyota sought to differentiate it from those cars with a unique look.
    OK, I said I wouldn’t talk about how this thing looks, but I lied. It’s stunning; somehow distinct from every other vehicle in the company’s lineup while also being recognizable as a Toyota. There isn’t a bad angle here, but I particularly like the way its lower door character crease and rear tail light extension lines create a sense of motion from the rear three-quarter view. The slope of the windshield is aggressive, and everything just works, especially in the Reservoir Blue of this tester. 19-inch alloys standard on the XLE and Limited models are sharp enough to draw compliments, but they come with an 8% fuel economy penalty—more on that later.
    Inside, the Prius’ vibe is more conventional Toyota. The dash is centered around a 12.3-inch multimedia display with wireless Apple CarPlay, while the driver gets their own seven-inch digital cluster. Leather seats are pleasantly supportive and even reasonably bolstered, and there’s plenty of storage for smaller items in the center console and door pockets. The funky four-gate Prius shifter is back, although some effort has been made to dress it up in leather. Next to it is a six-by-two-inch slot that staff writer Peter Nelson called “the single best phone holder-slash-charging pad that's ever been conceived,” a title I’m inclined to agree with.
    Rear legroom is spacious for two people, but three is a pinch. The sloping roofline—great for looks and aerodynamics—is less great for cargo room. A long weekend’s luggage for two fit just fine, but three suitcases was pushing it. The Prius’ duties under my care also included schlepping some of The Drive’s office junk around, and I found the low roof problematic there, too. In case you were wondering: an Aeron chair will fit in a Prius, but only if you load it through the rear door and not through the hatch. As much as it pains me to admit it, in our wagon-deprived world, I get why people who haul a lot of gear around buy SUVs.
    The Prius is powered by a 2.0-liter naturally-aspirated four-cylinder engine and a permanent magnet AC synchronous electric motor, working together through a continuously variable transmission and Toyota’s patented Hybrid Synergy Drive. Its combined output of 194 horsepower is up 73 over the previous model while maintaining similar mpg figures—an impressive accomplishment.
    Driving the Toyota Prius
    “Competent” is the word I’d use to describe the new Prius’ performance and driving dynamics. Acceleration is adequate if not enthusiastic, steering is accurate, and you can now actually tell what the front wheels and chassis are doing in a corner. Its battery-fed torque won’t leave you flat-footed on a highway merge or red-light dash. Once you’re on the interstate, the ride is well-controlled, and Toyota’s standard assisted driving systems do a decent job of minding the road.
    I did notice that the car’s Lane Tracing Assist ping-pongs against lane markings more than I’ve noticed with Hyundai’s system, for example. Radar-guided adaptive cruise control also refused to engage on a couple occasions, with no explanation given—but retrying minutes later solved the issue. These are minor nitpicks in an otherwise excellent highway cruiser and around-town commuter, especially one with a price tag in the low $30,000s. While I still wouldn’t call it exciting, driving a Prius is no longer a sacrifice.
    The Highs and Lows
    The Prius slips into your life rather than the other way around. It does pretty much all the things most people need a car to do and asks very little in return. Before long, you barely notice it’s there, and I mean that as a high compliment.
    You’ll barely notice the fuel bills, that’s for sure. I picked up the Prius with a full tank, added 650-ish miles, and returned it half full (or half empty if you’re a pessimist). In between, I added 30 bucks of 87 octane. I didn’t think once about whether I’d make it to my destination, or where I’d charge when I got there. I just sat down, put my phone in the wireless charging slot, and went. The infotainment system in the Prius Limited is intuitive, and the interior materials are of above-average quality. Highway road noise is present but not excessive, I didn’t observe any squeaks or rattles, and the JBL sound system indeed bumps. It was the lowest-stress driving experience I’ve had in a very long time.
    The gasoline engine’s integration at low speeds is slightly less seamless. The first time it wheezed to life I was startled by its volume and agricultural sound, especially in contrast to the car’s otherwise silent operation. A button-selectable EV mode allows for cruising on battery power alone when driving around town, but it automatically switches off any time you exceed 26 mph.
    Toyota Prius Features, Options, and Competition
    The 2023 Toyota Prius starts at $28,545 including destination for the base LE trim, which includes an eight-inch touchscreen and Apple CarPlay. There are three main trim levels: LE, XLE, and Limited, with front-wheel-drive and all-wheel-drive variants of each. The Limited AWD model starts at $36,960 including destination, and my Limited FWD tester’s sticker price was $37,494, with parking assist with 360-degree cameras, a digital rearview mirror, and heated rear seats selected as options.
    The Prius has few direct competitors, with the Hyundai Elantra Hybrid and Kia Niro Hybrid representing the most apples-to-apples comparison. They offer similar efficiency at a slightly lower price but lack the Prius’ proven track record. The Honda Insight is dead for 2023, and the Civic Hybrid will arrive with the larger Accord Hybrid’s powertrain for the 2024 model year. Given the 11th-gen Civic’s excellent platform, that’ll be one to watch for.
    The Prius’ biggest competition might come from its plug-in sibling, the Prius Prime. It’s about a $5,000 upcharge, but the Prime boasts a 40-mile all-electric range, meaning if your commute is short enough and you have somewhere to plug in at home or work, you might rarely use gas at all.
    Fuel Economy
    EPA
    The Prius has always defined itself—literally, its previous odd shapes and proportions were born in a wind tunnel—by its fuel economy. It’s still the best in its segment. The 2023 Toyota Prius in front-wheel drive LE trim gets 57 mpg in the city and 56 on the highway, per the EPA’s official tests. Those figures drop to 54/53 for the LE AWD variant, and 52/52 for the front-wheel drive XLE and Limited models with 19-inch wheels. It seems silly to compromise the Prius’ standout attribute for aesthetics or a slight gain in traction, but at least Toyota gives buyers the option. I’d be fine with the base wheels, front-drive, and a set of snow tires, but it’s a shame that the higher trims force an upgrade to less-efficient rolling stock.
    I managed an impressive 50.4 mpg over about 650 miles of mixed highway, urban, and back road driving. That’s in heavy traffic conditions and with the AC blasting. I remember my dad being thrilled to get 43 mpg in his 2005 Prius—a car that took over 10 seconds to accelerate from zero to 60 mph and felt like a tin can filled with plastic screws. It’s hard to complain about that.
    Value and Verdict
    In today’s market, the 2023 Toyota Prius represents a solid value. For a price in the $30,000s, you’re getting a well-made, pleasant car that gives a lot in terms of features and asks very little in return. It’ll save you money on fuel while hedging bets on electrification for another 10 years. Toyota’s track record of reliability and the Prius’ resale value on the used market should only inspire confidence that it’s a solid investment.
    The Prius is also still a car you buy for its fuel economy. But it’s no longer a symbol of austerity—of what you’re giving up in the name of efficiency. Instead, it’s a practical reminder that smart can be sexy and compromise can be cool. In the face of blunt EV extremism (both for and against), the Prius is a nuanced, tactful argument for why we should all probably be driving hybrids. Unlike Bruce Wayne, it’s the hero Gotham needs right now.
    #491 Nntw, Oct 9, 2023
    otatrant likes this.
  12. Tideland Prius
    16,597
    Plug-in powertrain is an efficiency win for the 2023 Toyota Prius Prime | Ars Technica
    otatrant and mountaineer like this.
  13. Tideland Prius
    16,597
  14. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Interesting they mention a drop in sales compared to 2022. Could it possibly be because they are not available in greater numbers from the factory? Sounds like an omission.
    Tideland Prius and Gokhan like this.
  15. Preebee
    867
    771
    Midwest
    2023 Prius
    Just lazy reporting.
  16. AndersOne
    AndersOne Active Member
    335
    195
    Europe
    2023 Prius Prime
    Toyota stockphotos and a text repeating infos about the car - how can they call this a test-drive/review?
    Here some cool crash - and safety tests:
  17. Preebee
    867
    771
    Midwest
    2023 Prius
    Wow! Thanks for sharing! Love watching all the high tech safety in action!
    The birds gently chirping in the background with the Prius hurdling towards the oblivious dummy was hilarious to me.
    It was also a little sad watching such a rare car get smashed over and over. I wonder if those same tests are ever performed on expensive exotic cars...
    Argyros and AndersOne like this.
  18. otatrant
    348
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
  19. Tideland Prius
    16,597
    The night time one is important. Good to see it performed well.
    Two things
    One, anyone annoyed that 60km/h GPS ranges from 62 to 64km/h on the speedo on those tests? It's not consistent. Most of the time, it was 63km/h.
    Second, it's nice they changed the warning chimes instead of the old fashioned beeps but this new one sounds like a casino jackpot chime :LOL:
    AndersOne likes this.
  20. Tideland Prius
    16,597
    Prius vs. Corolla Hybrid
