Rear seat seatbelt chime
Discussion in 'Gen 5 Prius Main Forum' started by mannymendez25, Aug 6, 2023.
  1. mannymendez25
    mannymendez25 Member
    67
    Miami
    2020 Prius
    The other day my daughter sat behind me and I drove away. She then decided to move to the middle of the back seat and seat belt chime for the seat right behind me never stopped beeping. I would assume if the seat didnt detect any weight it would stop but didnt. My daughter had to insert the seatbelt so the chime would stop. Anyone else experience this?
  2. Hammersmith
    Hammersmith Senior Member
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    There is an option to disable the rear seat warning. I don't know if that's what this is, or if you want to actually disable it, but you could try it out to see.
  3. mannymendez25
    67
    Miami
    2020 Prius
    I believe the rear seat warning you are referring to is if you have a baby, every time you turn off the car, a reminder is displayed so you dont forget your child in the car seat.
  4. 2023prius
    2023prius New Member
    california
    2023 Prius
    I'm dealing with the exact same issue in my 2023 prius. I have to keep the rear middle seatbelt buckled at all times now or it will beep incessantly.
    Did you find a resolution to this?
    I ordered seatbelt extenders on amazon thinking that might stop the beeping but they only fit the front seats and not the rear ones, if anyone knows where to get working rear seatbelt extenders for a 2023 prius I'll gladly order them.
