At the end of my wits with P0172 code.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by munis, Jan 18, 2023.
Tags:
  1. munis
    munis New Member
    Ontario, Canada
    Hey guys,
    I am constantly getting the P0172 System too rich code even after cleaning the MAF sensors and changing both O2 sensors. Can anyone tell me how to properly diagnose this code and get this sorted properly. I am going insane right now. Toyotas were supposed to be simply to fix simple issues for. This is getting insane. Took it to the dealership and they charged me three hours of diagnosis to tell me what I already knew, change O2 sensors. Which I did. But the codes are still there.
  2. Tombukt2
    13,219
    2,390
    What is your gas mileage right now That's the big question me personally I don't really care about the check engine light or codes because I live in a county and a state that I don't have emissions longhorn turn on lights get sticker and go but I do care if it's affecting my gas mileage I've had an '04 to 0 code now for 2.7 years still get 47 miles to the gallon so I really don't care about that code or the catalytic converter low threshold or any of that because it's not what affecting me or my gas mileage which is why I own the car your results may vary living in high regulated states where everything must be just so. I was just curious whether you're gas mileage was down because of this usually people notice that before they even think about the light being on
  3. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Welcome to PriusChat!!
    Did you purchase OEM or Denso sensors for the dealer, or a reputable parts house?
    Three hours is excessive, to say the least. Will they credit the 3 hours towards the repair labor if you buy new sensors from them?
    Here is the workup for DTC P0172 ( and DTC P0171) : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/05/2054m/cip0171.pdf
    FYI : you're moderated until you've posted 5 times.
  4. ChapmanF
    18,412
    That sounds like you've assumed the sensors were wrong and lying about the mixture being too rich.
    Which is possible. But it's just as possible the sensors are fine and doing their job and telling you the mixture is too rich.
    So that's also worth checking into, especially as you've already come up empty on the sensors-were-wrong path.
  5. dolj
    dolj Senior Member
    8,494
    4,312
    Wellington, New Zealand
    As part of the 3-hour 'diagnosis' by "the dealership", did they test for unmetered air getting into the system?
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,071
    1,988
    NJ-USA
    That would result in the MAF sensor under reporting and a P0171.
  7. mr_guy_mann
    4,071
    1,988
    NJ-USA
    What scantool do you have? My first step is to look at freeze frame data for the code and see when it set- rpm, temperature, fuel trim numbers, etc (record that data).
    Next is to monitor ECM scan data when the engine is warmed up (ECT near 180°F). I want to see Short Term and Long Term Fuel Trim, A/F and O2 sensors at: idle, high idle, and steady throttle cruise (when the engine is running).
    The upstream A/F sensor is normally around 3.3V, it goes lower (towards 2.0V) when the exhaust gases are "rich", and higher (toward 5.0V) when "lean". Then downstream O2 sensor reads near 1.0V rich, and near 0V lean. Normally is around 0.7-0.8V when engine is hot, running ok and cat is "good". You can use the O2 sensor to "validate" the A/F sensor and FT numbers. (If A/F and FT say "rich", but O2 reads 0V, then something ain't right).
    Short Term FT responds to A/F sensor. Goes (+) % when A/F reads lean, and (-) % when A/F reads rich. If STFT goes "too far" away from 0, then Long Term FT makes a correction to bring it back. This correction is stored in ECM memory for that particular combination of RPM & load. (ST + LT = Total fuel trim).
    Ideally fuel trim should be near 0 +/- 5%. 10% is "ok". 20% is a problem and likely sets codes.
    So get those numbers and report back.
    There are only so many possible "causes".
    1) the MAF is lying 2)the A/F is lying 3)the injectors flow too much fuel 4)fuel pressure too high 5)purge valve is sucking fuel 6)engine "timing" is off which throws off the expected Volumetric Efficiency.
    The data should help guide what path the diagnosis takes to confirm or eliminate some of those possibilities.
    mookie60 and SFO like this.
  8. munis
    munis New Member
    Ontario, Canada
    So after putting the car in maintenance mode and let it idle, the AFR Sensor reports voltage below 3V. But when the car is driving it is usually in its normal 3.3V operating range. Increases to 4.95V once throttle is cut which is expected.
    Short Term FT averages around 0 percent but Long term is -12.56% during driving normally. But idling in maintenance mode, it goes short term goes to -21% and long term goes to -27%.
    O2 sensor reads .8 to .9v continuouslty during idling. During normal driving operation it is around 0.7v. My understanding was that during driving normal operating voltage is 0.5v to 0.7v.
    I also got a P0420 code showing pending. So is it possible that it is the cats that have gone and the sensors are reading everything correctly? That is an explanation. Car has 350000km on it.
  9. mr_guy_mann
    4,071
    1,988
    NJ-USA
    Ignore the P0420 for now- the engine isn't running properly at idle, which is when it performs the cat monitor test.
    The system is in control at cruise. Sensors read as expected, the -12.5% LTFT is compensating but it can do it.
    Not so at idle. Both sensors report rich but total fuel trim is almost -50%.
    Here are known good MAF readings at different conditions- how does your car compare? (these were taken at under 1000ft elevation. If your altitude is much higher, you can adjust your values).
    SFO likes this.
  10. munis
    munis New Member
    Ontario, Canada
    Thanks a lot for pointing me in the direction. I checked my MAF readings with what you provided as a baseline and it was completely out of order. So I changed it and the car has been driving amazing since. Fuel economy went from 6.4L/100km to 4.5L/100km.
    Both trims are around 0% most of the time now. But I am stilling getting a P0420 code which might mean my CATs really must be weak now. So I am thinking just puttting an extender on it and see if I can get rid of the code that way.
  11. N88GUM
    N88GUM Junior Member
    Uk
    Have you changed your brake pedal switch at all?
  12. N88GUM
    Uk
    Munis, did you get a resolution in the end or are you still stumped...?
  13. N88GUM
    Uk
    Pcv valve swapped out even though it still rattled and it's sorted my issues...
    SFO likes this.
  14. N88GUM
    Uk
    Code back, so now left my injectors in cleaner for a few days and replaced the injector seals.
    Replaced and it's now been a few days and all good so far. I cannot believe that it may have been the injectors all along. Suspect initially the rubbers injector seals at the manifold were dry and cracked. Together with the injectors needing a flush, that's all it may have been.... Engine is on 130k miles only.
    SFO likes this.
  15. Tombukt2
    13,219
    2,390
    That shocking on all my 200 plus thousand milers here that I can see out the window none of this has been done I'm pretty much sure of it I have the history of all of these vehicles in their glove box almost every receipt through Toyota warranty and everything is with these vehicles I have not seen anything about injectors o-rings fuel rail or any of that and any of this series of paperworks. 130 k my God you're not even broken good but then again if this is a generation 3 well maybe.
