Head gasket issue
Discussion in 'Gen 3 Prius Main Forum' started by DiscoCat, Oct 14, 2023.
  1. DiscoCat
    DiscoCat New Member
    28
    Mojave Desert Utah
    Three Touring
    Is there a fix or preventative measure for fixing the head gasket issue?
    Does replacing the entire engine a solution to the head gasket issue?
    V Sport Wagon likes this.
  2. JC91006
    JC91006 Senior Member
    16,768
    8,565
    head gasket issue plague the 3rd generation 2010-2015 cars. Replacing the entire engine will be a good solution, as long as the replacement engine doesn't have this problem
  3. bisco
    51,906
    put a gen 4 engine in
  4. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    It would cost you more to put in a replacement engine than it would to repair faulty gasket if it were to fail.. Not all prius motors fail... Mine failed at 350,000 miles but only cot £1000 to have repaired properly... Secret here is if it does fail DON'T PUT HEAD SEALER In it will just make repair more expensive.
  5. Mendel Leisk
    41,432
    Clean the complete EGR system every 50k miles.
  6. bdc101
    bdc101 Member
    250
    89
    usa
    Has someone determined how the EGR makes the head gasket blow?
  7. Mendel Leisk
    41,432
    Maybe more succinctly, do you mean "does an EGR system clogged with carbon cause head gasket to fail?". All I can is, based on what I've read here, I think it does, and both to preserve the engine on our '10 and to test the connection, I'll follow the 50K cleaning interval.
  8. bdc101
    bdc101 Member
    250
    89
    usa
    Yes, the posts I have read seem to indicate that this is a foregone conclusion, and I understand that the Corolla motors don't really blow the HGs very much. I just don't understand how clogged EGR could cause head gaskets to blow.
  9. Mendel Leisk
    41,432
    And so how will you proceed with yours, eschew the cleaning?
  10. ColoradoBoo
    ColoradoBoo Senior Member
    1,240
    827
    Monument, Colorado USA
    Yes, EGR cleaning is vital...lots of info on this in here. Also, changing the oil and coolant regularly also helps prolong the life of the head gasket. (My oil gets changed every 5,000 miles, or 6-months, and the coolant, both radiator and traction, every 5-years or 50,000 miles.) We have three Toyota's that are 2008's and none have lost a head gasket, thank Goodness.)
  11. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    when there’s no vacuum to be had from the valve side, the intake will suck harder from PCV side which means more oil straight into that intake and the head. It’s a very strong cause for the gasket failure among a few internal oversights on build quality from the factory. I’d say a dying or dead water pump is MORE of a culprit but…
    Brian1954 likes this.
  12. bdc101
    bdc101 Member
    250
    89
    usa
