hood slightly misaligned, sign of undisclosed damage or common issue?
Discussion in 'Prius c Main Forum' started by k1ngn0thing, Oct 15, 2023.
  1. k1ngn0thing
    k1ngn0thing Member
    205
    49
    MA
    2016 Prius c
  2. k1ngn0thing
    k1ngn0thing Member
    205
    49
    MA
    2016 Prius c
    also, I don't understand the sales chain, namely how this used car dealer is making money if they purchased it directly from toyota. upload_2023-10-15_22-53-59.png
  3. douglasjre
    douglasjre Senior Member
    1,877
    653
    Orlando, FL
    Bent subframe. Right front corner with struck. Is also a gap between the headlight and the bumper cover.
  4. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    Make sure the apparent misalignment is real and not just a trick of the light or bad photography.
    You should understand that the Prius c is just about the most automatically-produced car in history. Fewer humans involved in its manufacture than just about anything.
    Robots. Robots that made each and every one of them incredibly identical to a fare-thee-well, much more so than any other car model out there including the big Priuseses.
    So you're very unlikely to find a c with a misalignment or uneven panel gap that was not caused by a crash or other bad thing.
  5. k1ngn0thing
    k1ngn0thing Member
    205
    49
    MA
    2016 Prius c
    body service performed right before sale at auction. must be an unreported accident. knew it was too good to be true.
  6. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    Personally I've never trusted carfax further than I could throw it, you appear to be finding out why.
    Good that you caught it!
  7. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    Well, it is possible that they repaired it appropriately from a mechanical standpoint. They'd never be able to get the body perfect because the c kind of redefined perfect from a manufacturing standpoint.
    But it does mean that it is on you to figure out if they fixed it properly with regards to its value as a used car.
  8. douglasjre
    1,877
    653
    Orlando, FL
    I have to prius' that are bent like this. I don't worry about it except that I had to do some fancy footwork to keep the plastic bumper cover in place because it doesn't line up with the radiator bracket
  9. k1ngn0thing
    k1ngn0thing Member
    205
    49
    MA
    2016 Prius c
    little bit of panel separation on front right corner and rear left corner but nothing major. looks like it was probably a very low speed collision with a stationary object. it handled fine at 75mph so I bought it.
  10. Sonic_TH
    Sonic_TH Active Member
    545
    88
    Puerto Rico
    Are there any videos of the manufacturing process of the Prius C? i would like to see it, so far i can't find any.
  11. k1ngn0thing
    k1ngn0thing Member
    205
    49
    MA
    2016 Prius c
  12. Sonic_TH
    545
    88
    Puerto Rico
    Thank you, i searched for that title and the video that shows up is showing humans assembling the bumpers and other few stuffs, looks like footage from the robots working has never been recorded or shared.
  13. k1ngn0thing
    k1ngn0thing Member
    205
    49
    MA
    2016 Prius c
    EDIT: not the C but probably similar.
