Newb Buying 2nd Gen
Discussion in 'Newbie Forum' started by BigDadSmallPrius, Oct 16, 2023.
  1. BigDadSmallPrius
    BigDadSmallPrius New Member
    Indiana
    I’m a newb. I’ve never owned a hybrid.
    but alas, I’m here looking for one.
    I found 2 local to me. They seem nice and well put together. Clean interior/exterior, both run and drive, no leaks/knocks/taps/sqeeks/squeels/etc.
    Higher mileage but both are in my price range.
    So my question is, with these 2 cars being at the height of my price range, how do I test the hybrid batteries to ensure they are good have good capacity?
    I know people are going to suggest the DrPrius app and the OBD plug-in scan tool. But alas, if I buy those(as cheap as they may be) I won’t have the money to buy the car because the prices are firm(I’ve already negotiated them to their bottom dollar amount).
    So, I’m wondering how I can ensure that the batteries are good, have good capacity, etc from just a test drive?
    I’ve obviously did my google searches as well as YouTube. But I haven’t sound a definitive answer as of yet.
    The stuff I found was after the car was already in need of a hybrid battery. Red Triangle, fast discharge/charge, etc.
    So, what can I look for while driving these to see if they have a good battery? Anything to look out for?
    Any tips would be greatly appreciated!!
    52,386
    Welcome!
    Unfortunately, there is no good way to test the battery capacity/life remaining.
    Even doc Prius or tech stream can only give you a snapshot of current health.
    It’s like going to your doctor for a checkup.
    They might tell you everything looks good, and then you have a heart attack on the way home.
    The saying around here is:
    If you’re gonna buy an old Prius, you better have a big rainy day fund
    BigDadSmallPrius likes this.
  3. txexplorer
    txexplorer Member
    55
    28
    It's worth $30 for the Veepak OBD2 bluetooth so you can run Dr. Prius and check the Modules, voltages, and other info. I also use Car Scanner it's another free app with useful info. Otherwise you'll have to take the battery out, take the case off and bussbars to test each module individually.
  4. Moving Right Along
    Moving Right Along Senior Member
    731
    588
    If you already know signs that a hybrid battery is bad (no power, rapid charging & discharging from full to empty, etc), then if the car is not doing any of those things, the hybrid battery is probably good.
    If you are adept as a mechanic or know one, you could inspect the battery fan to see if it’s clogged. A relatively clean battery fan should indicate a fairly healthy battery.
    Ultimately, you’re buying a 14+ year old car. More Prii make it to 200,000 miles plus than most other car models, and as a rule, they are very reliable. And if you’re buying one now with lots of miles, it was probably well cared for. But it’s also old. 25% of cars on the road are 16 years old or older, and only around 12% are 20 years old or more. So the statistics say on average, less than half of the 2nd Gen Prii currently on the road will still be running 6 years from now. That just means you should consider the length of time you plan to own the car.
    #4 Moving Right Along, Oct 16, 2023
    txexplorer likes this.
