Services canceled and car removed from app
Discussion in 'Gen 5 Prius Main Forum' started by CruisnGrrl, Oct 17, 2023.
  1. CruisnGrrl
    CruisnGrrl Active Member
    149
    128
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I got an email stating my connected services have been cancelled and my car removed from the app, check the app and yes my car is missing. I haven't even had the car 6 months. Anyone else have this issue? I'm on ignore with Toyota right now.
  2. otatrant
    otatrant Active Member
    346
    210
    San Francisco
    2023 Prius Prime
    XSE Premium
    What happens if you go into the car and set up the Toyota app again like you did originally?
  3. Gokhan
    Gokhan Senior Member
    6,441
    2,571
    Paramount CA
    Is it because your free trial ended?
  4. CruisnGrrl
    149
    128
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    haven't tried because I don't want them to charge me
    5 months is an odd number for a free trial. Also it's supposed to be something like 3 or 5 years
  5. CruisnGrrl
    149
    128
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Tried and it won't generate the QR code to connect.
  6. thnok
    thnok Member
    122
    44
    2023 Prius
    Did you try to reset the car through the multimedia unit?
  7. CruisnGrrl
    149
    128
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Been waiting on hold for an hour trying to get through to Toyota. I think their phone system must be broken because the last 10 minutes there have been zero callers ahead of me.
  8. CruisnGrrl
    149
    128
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
  9. otatrant
    346
    210
    San Francisco
    2023 Prius Prime
    XSE Premium
    It looks to me that it is pretty easy to delete your vehicle in the app accidentally. Here is a screenshot on iOS of the Remove Vehicle button in the app.
    I think they can only charge you if you have put your credit card into the wallet of the app on the fiance tab.
    Here is another screenshot of the Finance Tab in the app showing my empty wallet.
    I would think if you add your car again like you did originally and since the subscriptions are tied to the vehicle vin there is a good chance it will know your purchase date and the date you originally activated your subscriptions.
  10. thnok
    thnok Member
    122
    44
    2023 Prius
    did you try to factory reset through this?
  11. BiomedO1
    3,962
    2,089
    SacTown, Ca
    Sounds like a trip to the dealership - Let them figure it out and tell you what happened...
  12. Gokhan
    6,441
    2,571
    Paramount CA
    It says 3–10 years of free trial depending on the feature. That's not it then. Try removing and reinstalling the app and reconnecting with the car.
  13. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    My 'connected services' ended yesterday, and when I got into the car, it had 'forgotten' my Android Auto; I had to go into my Bluetooth settings and connect it again. On the other hand, I was concerned that my app would have my car settings disappear as well, but was able to get into the app. One weird thing was that I had to accept a whole bunch of 'connected services' disclaimers, although I am not connected to it. Weird. Meanwhile, the app is working like it should again. Safety Connect, Service Connect is active, up to 10 years, and Remote Connect is active until 1 year from purchase date.
  14. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    I had an update on the app yesterday. I wonder if that has/had anything to do with it. App is still working and no interruption of connected services.
  15. Argyros
    275
    142
    2023 Prius
    Weird...I thought it might be an update of the app, but when I went to check to see if there was one, it stated 'up to date'
  16. daisy555
    daisy555 Senior Member
    1,727
    715
    CT
    When I was looking at the free trial subscriptions for the 2023 I thought they maxed out at 1 yr except for the one that keeps track of vehicle maintenance/service. I think the trials were longer before.
  17. BiomedO1
    3,962
    2,089
    SacTown, Ca
    The length of free service, used to relate to model. On my 2021 LE it was only a year; while XSE got 3-5 years free.
  18. daisy555
    1,727
    715
    CT
    Website states “up to” 10 yr trial for service and safety connect for XSE and XLE whatever that means.
  19. Gokhan
    6,441
    2,571
    Paramount CA
    Those numbers are for OP's country Canada. US Gen 5 has no free trial (at least on cloud-navigation etc. features) on some trims and only one year on others. Gen 4 had a free three-year full trial.
  20. HacksawMark
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    The US gets Remote Connect trial for one year, Safety Connect for up to 10 years and Drive Connect, no mention of a trial period.
