Anyone have random stereo volume fluctuations?
Discussion in 'Gen 5 Prius Main Forum' started by Jim Stoll, Oct 20, 2023.
  1. Jim Stoll
    Jim Stoll Member
    75
    45
    NC
    2023 Prius
    LE AWD-e
    At first, I thought it was the auto-level stereo volume setting, but I turned that off, and it's still behaving the same. Every now and then, the stereo volume goes lower or higher. I've not yet been able to discern any type of pattern (I thought maybe it was when transitioning from engine to charge, or engine to EV, but that doesn't seem to be it.) It's merely a minor annoyance, but I'd really like to understand what is causing it. Curious if others are experiencing the same thing?
  2. Leadfoot J. McCoalroller
    8,152
    7,656
    Pennsylvania
    2018 Prius c
    do you have volume buttons on your steering wheel?
    Sometimes the clockspring cable wears out resulting in odd behavior from systems that are controlled via steering wheel buttons.
  3. ken2023
    ken2023 Member
    71
    55
    new jersey
    2023 Prius Prime
    XSE Premium
    There is an "Auto Sound Levelizer" that adjusts the volume based on speed. I've also noticed it jacks up the volume when I set it to Park. There are some options on the multimedia screen for changing that. But that's probably what you hear.
    EDIT - nevermind, just noticed you said you turned that off.
  4. Jim Stoll
    Jim Stoll Member
    75
    45
    NC
    2023 Prius
    LE AWD-e
    This is a brand new Gen 5 that I've had for a week, so I hope to heck it's not a worn out cable already. :) (But, if a cabling issue is a possibility, I'd definitely want to know about that, so Thank You.)
    daisy555 likes this.
  5. Jim Stoll
    Jim Stoll Member
    75
    45
    NC
    2023 Prius
    LE AWD-e
    Yes, that's what I initially suspected, as well, but I turned that feature off, and the fluctuating volume still persists. :-/
  6. Leadfoot J. McCoalroller
    8,152
    7,656
    Pennsylvania
    2018 Prius c
    Keeping your profile up-to-date can minimize this sort of confusion.
  7. Jim Stoll
    Jim Stoll Member
    75
    45
    NC
    2023 Prius
    LE AWD-e
    Yeah, I tried to update my profile, but it would only let me specify one Prius, and I now have two - 2008 and 2023. Is there a way to list multiple?
  8. Leadfoot J. McCoalroller
    8,152
    7,656
    Pennsylvania
    2018 Prius c
    I don't know of one, sorry. Old forum software has real limits.
    On the other hand, two Priuseses seems like a nice problem to have :)
    Cruzctrl1 likes this.
  9. Hammersmith
    Hammersmith Senior Member
    2,329
    2,387
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Are you using a single source when noticing the fluctuations, or are you switching between sources? I've noticed the system isn't great at equalizing volume between sources with significantly different levels. (For instance: streaming from your phone sounds fine, but the system blasts you when you switch to OTA radio.)
  10. Jim Stoll
    Jim Stoll Member
    75
    45
    NC
    2023 Prius
    LE AWD-e
    So far, I've only noticed it when playing music via the FM radio. I listened to an audio book via Car Play for numerous hours on the way home from picking the car up from out of state, and didn't notice it then. I'm not 100% sure it's only happening w/ FM music, but that's the only time I've consciously noticed it happening thus far.
  11. Mendel Leisk
    41,951
    That does not seem “by design”.
  12. Trollbait
    12,691
    To be clear, is this happening with just one station or several?
    Had this happen with one of my presets. Could be the station, but I think solar weather has been quite active in the past few weeks. That can effect radio signals.
  13. ColoradoBoo
    ColoradoBoo Senior Member
    1,275
    881
    Monument, Colorado USA
    Oh no...good old Toyota mulitmedia bugs!
    My 2014 Tundra infotainment system would spontaneously freeze up or just randomly reboot itself....even lock up while I was talking on the phone via the speakers. Had dealer check it out and was told they are "buggy" but to watch for TSBs on them. (Didn't see any)
    A couple of years later (and many many reboots), Toyota had a software upgrade which I downloaded onto a thumb drive and installed (NOT an easy process...also very buggy) but it finally took and now it seems to be working as-advertised. Good idea to periodically check what version is out and update as-needed.
    This is the link to see if your car has an update available:
    Updates | Toyota Software
  14. ColoradoBoo
    1,275
    881
  15. Ronnie5
    Ronnie5 Member
    49
    56
    2023 Prius
    I disabled auto-level as well, which helped, but I still notice it from time to time. I'm mostly streaming music via wireless CarPlay. I haven't been annoyed enough to actually try to isolate if it's only certain songs or if it only happens with CarPlay. Now that you say you notice it with the radio I guess I can eliminate blaming my phone. Since you didn't notice it while listening to an audio book, maybe the sound system is just not very good at certain frequencies.
  16. Ronnie5
    Ronnie5 Member
    49
    56
    2023 Prius
  17. Sharol
    Sharol Member
    162
    76
    Kansas, USA
    2023 Prius
    Is your phone bluetoothed (is that a word) to the car? Our HyCam AND my new Prius lower the volume when we get text messages (for that matter any notifications) on the phone. Even notifications that don't display on the car display. It just dips for a bit and then goes back to normal.
  18. Ronnie5
    Ronnie5 Member
    49
    56
    2023 Prius
    I my case it's a much more subtle decrease in volume.
  19. Jermo
    Jermo New Member
    Alabama
    2023 Prius Prime
    XSE Premium
    Mine too. At lower volumes you barely notice it, but if you have volume above 35 with more bass, the change is drastic. I haven't noticed it with audiobooks, but spotify is terrible.
  20. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    The only thing I've noticed is that AM stations seem to be much quieter than FM for some reason.
