Did you know Prius Gen 5 has auto lane change assist?
Discussion in 'Gen 5 Prius Main Forum' started by thnok, Oct 21, 2023.
  1. thnok
    thnok Member
    122
    44
    2023 Prius
    A fellow redditor mentioned this and I just saw this on the Toyota manual. (page 239 for Prius).
    It is mentioned as Lane Change assist, but says "if equipped". Yet there is no mention of being equipped anywhere other than lane trace assist.
    and this is how to use it.
  2. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    There are more advanced features offered in other markets.
    In my case with bZ4X, you can park with your phone from outside the vehicle... elsewhere, not in this market.
  3. bisco
    51,843
    wouldn't it be on the monroney sticker?
  4. Hammersmith
    Hammersmith Senior Member
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I haven't gotten it to work on my Limited with all options, but I haven't tested it enough to be absolutely certain my car doesn't have it. I haven't seen any other US HEV owners confirming it works. I have heard US Prime owners saying they've gotten it to work. It makes me think the Prime has it and the HEV doesn't in the US market. But I'm more than willing to be proven wrong if an HEV owner out there has gotten it to work.
    thnok likes this.
  5. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    According to page 99 of the owner's manual, the switches controlling LCA and FCTA (Front Cross Traffic Alert) should be in the Vehicle Settings menu between the Driver Break Suggestion setting and the TPWS (Tire Pressure Warning System) setting. If they are absent, the car does not have the option.
    I don't believe that any non-Prime Prius has access to that option. I'm guessing that the necessary radars were part of the spec for ordinary at one time but they were dropped at some point. Unfortunately, the manual was written to the spec. There is a lot of evidence that the manual was completed in a hasty fashion (spotty internal links in the PDF version, for example) and that the documentation folks forgot to remove these sections when the radars were removed from the spec.
    Note that I have a fully loaded Limited. The attached photo shows that the Vehicle Setting Menu jumps directly from the Driver Break Suggestion item to TPWS.
    thnok likes this.
  6. Will B
    Will B Active Member
    440
    404
    Denver
    2023 Prius Prime
    XSE Premium
    The feature is available in my PPPXP. I certainly wasn't sure if it was available either by reading the manual! The way I finally found out was that it has a bunch of settings so scrolling through them is where I saw that my car had the feature.
    will
    thnok likes this.
  7. stearicom
    stearicom Member
    81
    25
    I have a Prius Prime XSE and discovered it when driving on the highway. You hold the turn signal stalk down and hold it there to signal to change lanes for like 4 or 5 signals and it will display on your dash. This is before you hear the click where the turn signal stalk stays in position where it constantly signaling. You let go of the turn signal stalk and it will display on the dash and change lanes. It's not a smooth lane change. But, it's cool to see it work. I won't use it as I can change lanes smoother.
    thnok likes this.
  8. thnok
    thnok Member
    122
    44
    2023 Prius
    Got point, I’ll also check on the XLE Prius. You might be right for this being just a Prime thing, kind of disappointing.
  9. thnok
    thnok Member
    122
    44
    2023 Prius
    Double Post
  10. Blackat
    Blackat Active Member
    455
    316
    Colorado
    2023 Prius
    Limited AWD-e
    Even if I have it, it'll be another option I disable. I have turned off at least half of them
