Gen3 working OBD for dr prius app?
Discussion in 'Gen 3 Prius Technical Discussion' started by Sarp, Oct 15, 2023.
  1. Sarp
    Sarp New Member
    Nc
    Hi which obd works on dr prius app? I wanna shut down all the beeping in this car.. Thx.
  2. kevinb70
    kevinb70 Junior Member
    Atlanta, GA
    http://www.amazon.com/dp/B00PJPHEBO
    ANDROID VERSION
    If you want the iPhone module, click the link to the android. There's a button on the amazon page to switch to the iPhone version ($23)
    Panlong OBD2 Scanner Bluetooth OBDII Diagnostic Tool Car Code Reader Turn Off Check Engine Light Support Android Torque App
    $14 on amazon right now. I just bought it a couple days ago and connected to run the tests. Once the elm connected with the phone, I purchased the Dr Prius app.
    I did turn off the bluetooth on my prius nav so my android phone wouldn't automatically pair with the nav. Then I paired my android to the elm module manually. Went into Dr Prius and the app saw the module.
  3. kevinb70
    Atlanta, GA
    derp doublepost
  4. Mendel Leisk
    41,662
    By “OBD” do you mean a Bluetooth dongle? Carista worked for me.
  5. Michael Kent Handy
    Michael Kent Handy Junior Member
    60
    Fort Worth, Texas
    Dr Prius shows you which ones work with Dr prius app. I chose the Nexas. It's highly recommended and not expensive. Cost is similar for most of the small plug ins that have Bluetooth to iphone or android. I have an android. I had to pay a one time 11.99 to get features that test the hybrid battery life remaining. Just make sure your inverter is fully in stage 4(fully warm) when you test.
