What do you fill it with? Is 10% ethanol OK?
Discussion in 'Gen 5 Prius Main Forum' started by priusmouse, Oct 20, 2023.
  1. Roqu3
    Roqu3 Member
    92
    63
    Lima
    2019 Prius c
    Chrisfix installed a E85 system on his Prius like two months ago and I was surprised of not seeing a discussion about that in this forum, as far as i know the guy uses that as his daily.
  2. Downrange
    Downrange Active Member
    372
    212
    2024 Prius Prime
    SE
    Thanks to all for useful info. I can see it's a complex topic.
  3. CoolPriusXLE
    CoolPriusXLE Member
    68
    32
    2023 Prius
    There are a couple of stations in my area which sells ethanol free. What is Toyota's position on that?
  4. Trollbait
    12,631
    As long as the right octane, it's fine. Just not likely worth the extra cost.
