Was this even off of a Prius? If so which generation?
Discussion in 'Gen 3 Prius Main Forum' started by Mike72903, Oct 24, 2023.
  1. Mike72903
    Mike72903 Junior Member
    57
    Fort Smith, Ar
    TLDR. Anyone know if this is off an earlier generation Prius or even off a Prius at all?
    Purchased off eBay from a seller with JDM engines in their account name. Figured they would know what they were talking about. IMG_1210.png Claim was it was for a 2010 to 2015 Prius. I installed and then discovered something wasn’t right other than the fact the brake pedal connector was too narrow. IMG_1210.jpeg I just exchanged the connector for my old one. The hydraulic connection for the 5th line that goes into the side of the actuator at 90 degrees from the other four was on the opposite side. IMG_0058.jpeg You can see here, It’s just blanked off and the actual connection is on the opposite side. When I contacted them they offered this solution. IMG_1213.jpeg Since I’d already exhausted my 77 year old body getting it bolted in I tried that. I got a check hybrid system error I could not clear with Techstream. I managed to get my old unit close enough to plug in and was able to clear the communication error. Plugged the replacement actuator back in and got the same unrecoverable error. Think this wasn’t for a 2010. Been returned and hoping to hear back from them before I start a claim with eBay and or PayPal. So which generation if any was this off of?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Looks like it belongs to a 2015 Toyota Aqua hybrid. There's some listed in ebay UK
    Could find nothing for that number in the 50 states Toyota websites.
    Mike72903 likes this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,462
    2,422
    Taylors, SC
    Could mean that it only works with a right hand drive car.
  4. Tombukt2
    12,924
    2,322
    But You have it installed now working or was there no work around usually the right hand drive stuff can move to the left and because the lines are changed one or two will usually be a little different but it's usually pretty easily overcome?.
  5. Mike72903
    57
    Fort Smith, Ar
    Thank you. It’s a weird one for sure. Wish I had noticed before I installed it.
  6. Mike72903
    57
    Fort Smith, Ar
  7. Mike72903
    57
    Fort Smith, Ar
    It caused communication problems when installed that were not clearable using Techstream. Plugged in original and communication issue went away. As TMR-JWAP speculates I don’t think it was for a US model 3rd gen.
  8. Tombukt2
    12,924
    2,322
    That is interesting I guess since my days of engine swaps in the '80s and early '90s they have made different electrical systems I guess for the US and the other markets certainly seems that way at least an '04 to '09 most of that stuff can flip flop in out of vehicles and work and communicate.
