Removing a Shower Faucet question
Discussion in 'Fred's House of Pancakes' started by shocker, Dec 16, 2006.
  1. shocker
    shocker Junior Member
    89
    Northeast
    Can anyone recommend a method for removing the "flange" on a shower faucet so that I can get to the stem and fix a leak. The shower valve socket wrench isn't long enough to reach the nut.
  2. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(shocker @ Dec 16 2006, 11:36 AM) [snapback]363113[/snapback]</div>
    Mine have a setscrew hiding at the bottom of the flange - feel around or look with a mirror. Try a Google search on the name of the faucet manufacturer looking for instructions. Good Luck!
    - Tom
  3. daniel
    14,487
    1,519
    Spokane, WA
    I may not understand the situation correctly. But when a socket wrench does not reach, I use an open-end or adjustible wrench, or a vice grip.
  4. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    You know you'll likely need to apply some heat to make a repair, right?
    Shower faucets usually are just soldered to thin copper pipe in the wall, and if you need to take it apart for repair (or in my case, flip the mixing ball over because the person who put it in put the ball in upside-down and my hot and cold water were reversed) you'll usually bend or rupture the copper tubing if you just put a big wrench on it and go for it. You usually need to apply some heat to loosen things up so the valve body can be taken apart without applying a lot of force.
  5. koa
    koa Active Member
    980
    45
    Hawaii
    It's kind of hard to advise without seeing what you have. Some screw off. Maybe a deep socket will work. Here's a pumbing site that has lots of good info in case you didn't know about it.
    http://www.terrylove.com/crtoilet.htm
  6. Alnilam
    Alnilam The One in the Middle
    760
    Carlsbad, CA
    This may surprise some, but PC doesn't stand for "Plumber's Chat."
  7. Syclone
    Syclone Member
    540
    <div class='quotetop'>QUOTE(Alnilam @ Dec 18 2006, 02:34 AM) [snapback]363642[/snapback]</div>
    This is truly a Zen moment!
    The title of the thread is the answer. :rolleyes:
  8. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(Alnilam @ Dec 17 2006, 11:34 PM) [snapback]363642[/snapback]</div>
    This is Fred's House of Pancakes. The place for anything unrelated to the Prius. If it's related to the car it does not belong on this forum. The shower faucet question qualifies.
  9. koa
    koa Active Member
    980
    45
    Hawaii
    <div class='quotetop'>QUOTE(Alnilam @ Dec 18 2006, 03:34 AM) [snapback]363642[/snapback]</div>
    Or "Political Chat."
  10. koa
    koa Active Member
    980
    45
    Hawaii
    Or "Punctuation Class."
  11. Alnilam
    760
    Carlsbad, CA
    <div class='quotetop'>QUOTE(daniel @ Dec 18 2006, 06:49 AM) [snapback]363715[/snapback]</div>
    I know, I know. Stop the stones! I was just kidding but forgot the Smiley! The PC caught my eye and I couldn't resist.
  12. jared2
    jared2 New Member
    1,615
    <div class='quotetop'>QUOTE(daniel @ Dec 16 2006, 03:52 PM) [snapback]363196[/snapback]</div>
    I call James Henderson, the plumber.
