Vsc, ABS ((!)) lights on with Red triangle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by avoice217, Oct 19, 2023.
  1. Brian1954
    Brian1954 Senior Member
    2,396
    960
    South Central PA, USA
    Specifically, which trouble codes do you think are saying that you have a bad abs actuator?
  2. avoice217
    avoice217 Member
    180
    22
    So based on the codes, you're saying that its actually something else and NOT the actuator itself?
  3. ChapmanF
    18,514
    Trouble codes can't tell you straight off what's causing the problem. An ECU can only tell you things it is able to notice, and it's up to you to figure out why. In this car, the brake ECU has noticed out of range voltage arriving at the ECU, and power not arriving simultaneously at the two redundant processors in the ECU. I can't tell you why it is noticing those things; somebody would have to do the troubleshooting in the repair manual for those codes. But it doesn't sound like anything where the actuator would be my first guess.
  4. Brian1954
    2,396
    960
    The trouble code that I would try to fix first is P0AA6.
    Also, put a charger on the 12v battery to make sure it is fully charged.
    How many miles on the car?
  5. avoice217
    avoice217 Member
    180
    22
    Ok well I did just order the bus bars for my hybrid battery and I knew it was about time to work on getting the battery worked on, so as soon as those come in, then I'll inspect it and go from there. Also I will get a multimeter to test the voltage on the 12v battery. Current mileage is around 254k.
  6. Brian1954
    2,396
    960
    For your own safety, I advise that you not work on the HV battery by yourself. Based on reading your other posts on this forum, I do not think you have the knowledge or tools to do the job.
    New bus bars most likely will not fix trouble code P0AA6. There is the possibility that you make the HV battery worse rather then better by working on it yourself. What will you do if you try removing the nuts on the bus bars and the terminal on the battery module snaps off? Can you afford two weeks of not being able to use your car while you work on the HV battery? Did you know that the nuts on the buss bars need to be torqued to a specific value when you reinstall them?
    The car has 254k miles. It is time to replace the complete HV battery with a refurb battery ($1500 - $2000 installed price) or a new OEM battery ($3200 - $3800 installed by a dealership). Are you willing to spend this amount of money on your car? If not, it may be time to look for a replacement vehicle.
  7. ChapmanF
    18,514
    Also, if one is going to work on the P0AA6 code, it would be good to get access to a scan tool that can show the three-digit INF code that goes with that code. Some of the INF codes will not point to the battery at all:
    Brian1954 likes this.
  8. avoice217
    avoice217 Member
    180
    22
    Hey Chapman so ive seen a video on that. Currently working on pulling up the codes again. So the good news is that I just checked the 12v battery and its good (showed 12.4v). However I just recently ordered some nickel plated bus bars per suggestion from a Youtuber who went through this. Right now I'm trying to figure out if I should just erase the codes temporarily and just drive the car a little until the new bus bars arrive or just go ahead and get the hybrid battery out.
  9. ChapmanF
    18,514
    Suppose you have an isolation failure somewhere in the car (that's the P0AA6), and you don't have the INF code for the P0AA6 so you don't know which region of the car the failure is in. You have one problem.
    Now suppose you take apart your battery, just because, and you start doing work on it, like changing bus bars, and something goes wrong while you're doing it. Or, you don't notice anything going wrong while you're doing it, but you put it back together and then see another code, this time pointing to the battery.
    Now you have two problems.
    That's the usual reason I urge people to work on pinning down what the one problem is, first, before going and working on some maybe-it-is-maybe-it-isn't part of the car just because.
  10. avoice217
    avoice217 Member
    180
    22
    So after getting the codes, unfortunately the scan tool wasn't able to give me the INF code. Therefore I have no idea what the secondary code is.
  11. ChapmanF
    18,514
    Somewhere in the world there is someone who has a scan tool you can either buy or rent or borrow or use to find out what the INF code is.
    Also, if you haven't got the INF code, you can still work through the P0AA6 troubleshooting steps in the repair manual, just starting at the top as if you only had 526 and checking all the branches. Just takes longer, is all.
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    Get the Autel AP200. $40 on amazon + shipping when I checked last week. Can read codes and data on all systems in a Gen2 - including freezeframe data and INF codes.
  13. avoice217
    avoice217 Member
    180
    22
    mr_guy_mann, so I just searched for that Autel AP200 and I actually just found the same one on eBay for a very similar price, so gonna go that route. I appreciate the feedback though.
