Daylight savings time change
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Hannah Andersen, Nov 5, 2023.
  1. Hannah Andersen
    Hannah Andersen Junior Member
    Dallas/Ft. Worth
    2022 Prius
    Does anyone know how to change the time for Daylight Savings Time on the Gen 5? I'm not sure where my user's manual is.
    51,831
    2022 Prius is gen 4, but if you have a gen 5, the manual is available online
  3. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    The information is on page 53 of the Multimedia Owner's Manual (not the encyclopic main manual). Briefly, if you use the "set Time by GPS' setting, there is nothing to do. As I discovered when I got into my car this morning, the clock time was 1 hour ahead until I started the car, at which time it was corrected.
    If you choose to set time manually instead, then fields for manually setting time appear.
    tovli likes this.
  4. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    I had to manually change mine today. Went into the setting menu and turned off daylight savings time.
  5. Ronnie5
    Ronnie5 Member
    47
    51
    2023 Prius
    I had to manually set my time. The system was set to adjust time automatically, but I guess that only works if you have the Toyota Navigation subscription.
  6. Will B
    Will B Active Member
    440
    404
    Denver
    2023 Prius Prime
    XSE Premium
    I still have the "free" (Included with purchase) subscriptions and have the car set the car to adjust time using GPS. The default for GPS time was off which I thought was weird, but changed it. With that, changes were completely automatic, not just for DST/not but also when crossing time zones on my big road trip. Kinda neat--especially when the change isn't something obvious like a state border as in Kansas.
    will
