Rigid 15 000 Km oil changes makes no sense IMHO
Discussion in 'Prime Main Forum (2017-2022)' started by niceandeasy, Nov 6, 2023.
  1. niceandeasy
    niceandeasy Junior Member
    Portuga
    Hello all
    I have a 2020 Prius PHEV and love it a fabulous machine, very much underated.
    I am located in Portugal , Europe, and the dealers here stick with 15 000 Km intervals for oil changes
    As I do at least 50% of the running in EV mode, it makes no sense to me this rigid schedule
    I would go for 25 000 Km intervals as I do a lot of driving and Km acumulate fast
    I am right ?
    Thank you beforehand
  2. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    No one can objectively and with overwhelming proof tell you that you are right or wrong. All you will get are opinions, some of them very strongly argued and/or held opinions. This even includes the opinions of Toyota and auto manufacturers and of course oil companies and sellers.
    But if you want to avoid denial of warranty claims you pretty much have to do what they say whether necessary in fact or not. My own, unproven, opinion is that you will get to the design service life of the vehicle and engine even if you never change oil as long as you don’t let the oil get low. But I won’t bother arguing the matter. Good luck
  3. Mendel Leisk
    41,824
    Toyota also stipulates “yearly”?
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    in the US, a manufacture can refuse warranty claims if you did not follow recommended service intervals. no idea in Portugal.
  5. bisco
    52,286
    Except that there’s no way Toyota can tell if you changed your oil or not Jumbo.
    So the warranty thing is a fallacy you keep perpetuating
  6. niceandeasy
    Portuga
    Many thanks for your replies.
    Yes, here is also 1 year/ 15000Km whatever comes first. As I do around 550 Km a week 15000 Km pass fast
    I am going to stick with 15 000 km+around 1500 Km intervals so that the warranty is not broken (the dealer is very good and nice, and there is some flexibility on their part when one fails the "perfect" 15 000)
    I am a longtime car enthusiast, and maybe you would like to know that Ferdinand (Ferry) Porsche, in his book "We at Porsche" of 1976, says that oild never degrades, just gets mixed with impurities.
    Already in 1976 he was very concerned with environmental problems at expressed his total disgust at the amount of oil changed without need and discarded in nature
    In the same token, there is also a fascinating chapter on a "long life auto" (30 years life span) to minimize pollution,
    A great book
    We at Porsche: The autobiography of Dr.... by Porsche, Ferry (amazon.com)
    Regards to all from Portugal
  7. niceandeasy
    Portuga
    double post, sorry, deleted
  8. bisco
    52,286
    You could have the oil tested, but that might be an unnecessary expense .
    However, testing it once might tell you everything you need to know
    Trollbait and MPGS-LOL like this.
  9. MPGS-LOL
    MPGS-LOL Junior Member
    Somewhere sperical, with lots of v8's
    This is the way.
    $40 well spent, though it kinda eats into the "save a few bucks by extending the OCI".
  10. MPGS-LOL
    This is the way.
  11. Trollbait
    12,653
    He's right. The oil keeps lubricating, but protective additives get used up over time. In time, the oil becomes acidic, and more metal to metal contact happens on start up and high loads. The oil change is to replace those additives.
    Toyota is just sticking to what they call for with their non-plug-ins cause it is easy. In their defense, it would be hard to pick a mileage or time number that would be safe to cover to potential range of EV miles a car could see.
    GM and Honda use a system that monitors temperatures and engine parameters to determine when to change the oil. A Volt could go two years between changes.
    The simple solution to reduce oil use with PHEVs as ones with longer and longer EV ranges come out would be what other industries use; engine hour meters.
    As for your question, you could safely go with longer intervals when out of warranty. Oil analysis can help with that.
    It would only be a cost for a handful of times. Once the change point is pinned down, it is no longer needed for the car sticking to that use cycle.
  12. Mendel Leisk
    41,824
    Yeah, that's the quandry.
  13. niceandeasy
    Portuga
    Thank you all for the extra insights
    Best wishes from sunny (usually) Portugal !
  14. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    About the engine warranty...if you bring the car in with engine problems and the insides are full of black goo, no warranty repairs for you. If the insides are clean and oily, you'll probably get the repairs without problem.
    Oil certainly does degrade with use. It oxidizes and turns to sludge, as well as the essential additives getting depleted...anti wear agents, anti foamants, anti oxidants, corrosion inhibitors, viscosity index improvers, pour point depressants, alkalinity improver, and others, about 10 to 30% of the finished oil by volume.
    Used oil is collected for several uses. A certain percentage can be introduced into the crude oil stream in a refinery and refined along with the crude. Used oil can be re-refined into a good quality lube oil. It can be used as part of the oil to make asphalt pavement and other asphalt products. A limited amount can be mixed into heavy fuel oil as cutter stock to improve the viscosity and specific gravity. In any case, it is not wasted nor just dumped.
    Back to the Prime oil drain interval...we probably use the engine perhaps 10 to 20% of the miles. No need to change that oil. Nor is there any good reason to have a 1 year interval. I've had diesel engines in intermittent use with the same engine oil for years, but we did quarterly oil analyses. Toyota picked a simple minded way to set the oil drain interval, and we're stuck with that unless you want to do periodic $35 analyses.
    Georgina Rudkus likes this.
  15. ColoradoBoo
    ColoradoBoo Senior Member
    1,264
    870
    Monument, Colorado USA
    I wish Toyota would come up with a way to know just how many miles we've put on the ICE engine, especially in the Primes. I monitor my hybrids while driving and, sometimes, the engine doesn't seem to run but about 30% of the time...so if I drove 45 miles the ICE only ran for 13.5 miles. This would greatly extend my rule of changing out the oil every 5,000 miles. (So I'm, probably, changing more like every 3,000 miles of engine run time.)
  16. Mendel Leisk
    41,824
    I think you have to answer that.
  17. rjparker
    10,411
    6,521
    No. Reduced use of the ice especially with stop start leads to increased fuel dilution that does not quickly evaporate off and causes increased carbon on upper engine parts experiencing thermal cycling many times per drive rather than once in a conventional drivetrain. You want the detergent additives to be at their most effective state.
    On my 2022 Rav4 hybrid there is a percent of ev operation that can be displayed. Typically I see 44% plus or minus in a vehicle with 90% highway driving. However I would never extend oil change intervals even to 10k miles much less more.
    Trollbait likes this.
  18. Trollbait
    12,653
    Aside for some extreme use cycles, the additives will get depleted before the degradation leads to sludging.
    It was a common practice back when Porsche made the comment. My father says he would just let the oil drain onto to gravel driveway back then. I suspect he wasn't unique for the time.
    Today, drips and spills still happen when oil changes are done, and the recycling has a cost to it. While greatly reduced compared to the past, there is still an environmental cost to too frequent oil changes.
    Toyota chose to simply use the interval they picked for their ICE models.
    High EV ratio in a hybrid could mean the engine sees the equivalent of short trips, which lead to shorter oil life.
    That may not be true for a PHEV. The EV miles can be from trips that the engine never turns on, and trips with engine use can be ones that adequately heat up the oil.
  19. Mendel Leisk
    41,824
    When I was a kid the gas station ‘cross the road routinely dumped used oil out back, down a small rock outcrop. It literally looked like hell.
    the stations still there, though pretty much eclipsed by the corporate self-serves in town centre. The dump areas all overgrown, but guess it’s all still there.
  20. rjparker
    10,411
    6,521
    The oil finds its way down to ground water or is washed off into streams and rivers. Not good either way.
  21. ColoradoBoo
    1,264
    870
    That's true...the start/stop technology found in many vehicles these days does introduce new wear-and-tear. Many vehicles even have a button allowing the driver to turn the feature off. I'll just keep doing my 5,000 mile/6-month oil changes and see how many miles I can get my Prius...never had a vehicle hit 200,000 so keeping it for the long-term. (I'm averaging 15,000 miles a year so should hit it in 2034.)
