Broken axle after accident. Safe?
Discussion in 'Gen 4 Prius Technical Discussion' started by Oh4Corolla, Nov 8, 2023.
  1. Oh4Corolla
    Oh4Corolla Junior Member
    Mass
    Hello all,
    Another driver t-boned me and insurance/body shop is indicating about $5,800 worth of damage including a broken axle (and lower control arm). They are planning to repair it. Should I be concerned with the safety of the vehicle after they fix the axle? It's a very important part of the suspension. Is it smart to have another mechanic check out the work after the body shop repairs the vehicle? Or should I sell/trade in the car?
    Thanks!
    51,529
    I don’t see any problem with replacing all the damaged parts, is your insurance company comfortable with it?
  3. bisco
    51,529
    Duplicate
  4. Mendel Leisk
    40,982
    The body shop may well subcontract the axle repair to mechanical shop, possibly even a dealership. That’s how ours operates.
  5. Kenny94945
    Kenny94945 Active Member
    844
    421
    Sausalito
    2016 Prius v wagon
    Replacing an axle.... IMO no big deal.
    Ditto for the A-Arm.
    I would say safe.
    What to look for?
    Are the mounting points for the A-Arm bent?
    Was the transmission case isolated from the breaking of the axle (assuming you meant the front)?
    Will they relace any rubber suspension components too?
    Does the car align within spec?
    No mention of the struct being damaged?
    In those regards, if you wish to go "a step further", yes, bring the car to a different alignment shop for an inspection and measurement after the repair. But that cost will be your responsibility unless they find issues then you'll re-involve your insurance.
    So, A-Arms and axle replacement IMO does not require selling/ trading the car.[these are standard repairs].
    But collision damage, and its tendency to bend things, is more concerning to me.
    Good luck with your decision.
    sylvaing and Oh4Corolla like this.
  6. Oh4Corolla
    Mass
    I'm going through other driver's insurance. So I feel like I'm suspicious of anything they do or don't do. I do, however, trust the body shop. We are repeat customers and they are a local, highly rated shop.
    ColoradoBoo likes this.
  7. Oh4Corolla
    Mass
    Very useful information! I will take notes and ask questions.
    I assume you meant "Strut" not "struct"?
    Thank you!
  8. Mendel Leisk
    40,982
    Again, you shouldn’t need to oversee the body shop. If there’s suspension or mechanical damage, beyond their scope of expertise, they will (or should) take the initiative, subcontract that work to a shop competent in those areas.
  9. BiomedO1
    3,152
    1,667
    SacTown, Ca
    Beware of clunking, popping, and squeaking over rough roads. If you experience any of that, take it back for a rework. Also look for your anti-skid lamp turning on abnormally or more frequently; that's also an indication that the suspension isn't set-up correctly.
