15.1 kwh per 100km ... what are other people getting?
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by Nntw, Nov 8, 2023.
  1. Nntw
    Nntw Active Member
    398
    246
    Toronto
    2023 Prius Prime
    So except for the drive back from the dealer, all my driving's been in EV mode.
    The car says 15.1 kwh/100 km... and I've put about 1340 km on.
    What are other people getting?
    Tideland Prius likes this.
  2. Nntw
    Nntw Active Member
    398
    246
    Toronto
    2023 Prius Prime
    Addendum- got the car in Sept, put the winter tires on at the end of Oct.
  3. Louis19
    Louis19 Active Member
    392
    368
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    see you live in toronto area , cannot say what are my Kw/h /100KM on my gen4 Prime but expect to see a degradation with winter tires and heating as the temperatures drops. As I see it , you can expect a 40% drop in EV efficiency in the horrendous winter driving conditions.
    after 20 000 KM the car indicates 1.7 L/100KM.....
    #3 Louis19, Nov 8, 2023
  4. Nntw
    Nntw Active Member
    398
    246
    Toronto
    2023 Prius Prime
    Thank you, yes, I figure it will go down.
    We also have a Rav4P, and its lifetime average electrical use is actually BETTER than the Prius'. So maybe it's just the Prius has driven fewer km, so it needs more distance and time for a more accurate average.
    Louis19 likes this.
  5. bisco
    51,562
    15 is pretty darn good with winter tires and heat
    Nntw likes this.
  6. Nntw
    Nntw Active Member
    398
    246
    Toronto
    2023 Prius Prime
    Thanks- that's good to know.
    ACTUALLY... today on the way home from work (401, west end Toronto ) we commuters had to contend with ice pellets and a temp of about 3C.
    So for the 2nd time since I brought it home (there was a cold morning a few weeks ago) the engine fired up when I defrosted the windshields.
    Rather than just saying 100% EV, 14 km, when I shut the car off, it said 1.89l/100km.
    So, yeah, winter's here.
  7. Tideland Prius
    16,506
    Given the longer range (which means there's more chance for the kWh/100km to vary), that's pretty good. And Toronto traffic isn't favourable for efficient driving. That's good. Of course.
    My average (over the 3 years) on my old Prime was around 13.4kWh/100km but much slower city driving. (16-19kWh/100km in the winter, 11-12kWh/100km in the summer)
    Nntw likes this.
  8. The Tramp
    The Tramp Italian Prius Expert
    375
    51
    Turin, Italy
    2020 Prius PHV
    On my 2020 Prius PHEV, I am floating on 8.5 kWh/100 km (or 85 W/km as I prefer), and I can get as low as 7 on certain trips, but now winter is coming and I've had her only since May.
  9. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    351
    272
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Average 14.45 kWh / 100km (4.3 mi/kWh) for 2900km (1800 EV miles)in 70 “EV days” flat Florida USA with temperatures averaging 85F. 2023 Prius Prime XSE
  10. Nntw
    Nntw Active Member
    398
    246
    Toronto
    2023 Prius Prime
    Ok thanks! I guess I don't feel too badly about my Prius' energy consumption, then. despite the 19" wheels.
    ...because I swear, the 2021 Rav4P seems to use LESS electricity.
    tovli likes this.
  11. mountaineer
    mountaineer Active Member
    145
    114
    Ontario
    2019 Prius Prime
    I got significantly better mileage on my 2019 Prius Prime – in summer, hovering at 10 kWh/100km.
    In the 2023 Prius Prime (19" wheels) I was getting closer to 13 kWh/100km in the summer, and it's climbing now with cooler weather (around Hamilton) to 15.
    Still have to find a winter tire solution. I really want all-weather 17", but nothing's available it seems.
  12. Nntw
    Nntw Active Member
    398
    246
    Toronto
    2023 Prius Prime
    Costco.ca shows a 17” Pirelli WINTER tire…. It’s never in stock.
  13. Nntw
    Nntw Active Member
    398
    246
    Toronto
    2023 Prius Prime
    CORRECTION- the rav4p's energy consumption is WORSE- noticed that today.
