Broken front axle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rickdamon, Dec 20, 2006.
  1. rickdamon
    rickdamon New Member
    I arrived at work this morning to find voice mail from my wife. "I hate cars. Call me."
    She had taken her Prius ('04, 95,000 miles) in for an oil change. The mechanic told her she needs a new left front axle. Has anyone else had this happen (a broken axle, not a call from The Wife <_< )?
    thanks,
    Rick Damon
  2. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    you sure it wasn't an axle seal?
  3. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(NomadVT @ Dec 20 2006, 11:04 AM) [snapback]364586[/snapback]</div>
    My sister broke the axle of her Honda Accord. We're still not sure how she managed that, anyway, if it's truly broken, you will be requiring the assistance of a tow truck. More likely the mechanic is pointing out a leaky seal as galaxee suggests, or a noisy CV joint or something similar.
  4. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    OR possible a drive shaft? At 95,000 miles it's quite likely that it's time to get the half shafts rebuilt or replaced. The CV joint boots may have also been torn, which speeds up the process. If it really was a broken axle, the car wouldn't have been able to move.
  5. rickdamon
    <div class='quotetop'>QUOTE(galaxee @ Dec 20 2006, 11:06 AM) [snapback]364589[/snapback]</div>
    I'll bet that's what it is. The mechanic asked if she'd just had a grease undercoating done. Evidently there was grease all around this axle.
    thank you,
    Rick Damon
    <div class='quotetop'>QUOTE(narf @ Dec 20 2006, 11:12 AM) [snapback]364598[/snapback]</div>
    Good point. I'm going to stay optimistic for a few hours and hope for a broken seal.
    thanks,
    Rick Damon
  6. cbs4
    cbs4 Member
    105
    Rick, the left side (driver's side) axle seal was defective on our 2006 Prius also. I say "defective" rather than "broken" because it began leaking with only about 9,000 miles on the car.
    I noticed it when changing the oil, just like your mechanic did, and had the axle removed and the seal replaced under warranty. The seal part number is 90311-35054.
    Hadn't realized what a common occurance this might be, as galaxee's immediate response indicates.
  7. galaxee
    9,810
    471
    MD
    actually my immediate response was because we did an axle seal on a 97 camry the other night.
  8. galaxee
    9,810
    471
    MD
    since i was just on the phone with DH i asked him about axle seal replacements- they are *maintenance items* and at 95k it's definitely normal to need a replacement. no worries.
    at 9k, well that is way too early but he has personally never had to replace one before 70-80k that he can remember.
    torn cv boots will also throw grease all over the underside of the car, in that case you definitely want to replace that before the cv joint goes.
  9. tochatihu
    tochatihu Senior Member
    9,854
    3,815
    Kunming Yunnan China
    2001 Prius
    Perhaps we are reading of the first Prius CV joint/boot failure right here. Had to happen eventually. Folks, please either get down there and inspect them yourselves periodically, or make sure that the shop does so.
  10. Moby Whaley
    Moby Whaley Junior Member
    56
    Sedona, AZ
    I went in for a oil change and I was told my CV Boot is leaking. I wonder if my 10yr / 100,000 mile warranty from Toyota will cover this? My dealer has to order the part and they are checking to see about my coverage with the warranty.
    <div class='quotetop'>QUOTE(tochatihu @ Dec 22 2006, 08:44 AM) [snapback]365640[/snapback]</div>
  11. tochatihu
    9,854
    3,815
    2001 Prius
    Moby, sorry to suggest that there is a good chance that anything rubber on the car will fall under some sort of 'wear and tear' warranty exclusion. Regardless, please do get the thing fixed because half-axles cost way more than boots.
    Other readers, *please* take a look at the important underbody components of your car, or get someone else to to so.
  12. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    Thats weird, I have never had a seal fail on me, Its always the CV shaft knuckle.
    Anyone know if greasing the boot is part of a regular oil change or do you need to request a quality check to get that done.
  13. Loveit
    Loveit New Member
    473
    What is a CV boot? I have no clue!
  14. donee
    donee New Member
    2,956
    198
    Chicagoland
    <div class='quotetop'>QUOTE(loveit @ Mar 9 2007, 11:02 PM) [snapback]403121[/snapback]</div>
    Hi Loveit,
    CV stands for Continuous Velocity, which is the technical name for the type of universal joints used in four places on the front wheel drive cars (typically). These joints are lubricated with grease, and in order to keep the road grime out and the grease in as they rotate and flex (as the wheels go up and down with bumps in the road) there is a rubber cover, called a "boot". These are accordian pleated rubber pieces that you can see by where each front drive shaft comes out of the transmission, and near where the drive shat terminates in the wheel hub. Inside the rubber is a fist sized pieces of complicated machined metal, that allows the rotation power to be transmitted to the wheel, even when the wheel is at different positions and orientations (like when steering).
    Check out this link:
    http://en.wikipedia.org/wiki/CV_joint
  15. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(TomorrowMatters @ Mar 9 2007, 09:52 PM) [snapback]403117[/snapback]</div>
    No, the boot is supposed to be hermetically sealed. You only put the special grease in when replacing the boot and/or CV joint. If you catch a failed boot early enough, you will save the expense of replacing the CV joint. It's usually cheaper to get a rebuilt halfshaft than to pay a mechanic to replace one CV joint.
    There is a new tool that also allows for very quick boot replacement. Check it out
    http://www.astoria2000.com/main.html
    It's a creepy looking tool though ...
  16. galaxee
    9,810
    471
    MD
    <div class='quotetop'>QUOTE(jayman @ Mar 11 2007, 09:40 PM) [snapback]403990[/snapback]</div>
    :blink:
    won't catch DH using that thing... there's no way it'll work with a normal boot, those have to be special boots that are flexible enough to do that.
    flexibility goes hand in hand with lack of durability.
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(galaxee @ Mar 14 2007, 12:35 AM) [snapback]405178[/snapback]</div>
    No doubt, but does the average consumer know that? All they care about is the cost of repair. The special boot carries a 1 year warranty
  18. jsorger
    jsorger New Member
    97
    Since my previous car was a Honda, I replaced my CV boots every 30k miles or so. I was told that Hondas had CV boot problems...
    A mechanic later told me to spray them with silicone spray every oil change. I have been doing it on my Prius since the first change. Don't know if it helps, but they don't appear to be dry at 80k miles.
  19. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Oddly, on occasion, I hear a light rhythmic clicking noise from the front end of my '04 when slowing to a stop that almost sounds akin to a CV joint. It prompted me to double-check that my CV boots weren't leaking (they're not).
    However now I have to wonder that because our cars use regenerative braking, if there's an increased load in the "reverse direction" on the CV joints. In theory that might accelerate wear on a less than adequately lubed joint.
    Any other reports of higher mileage Prius going through CV joints or axles (in cases where the boot wasn't compromised or worn and grease was still in place)?
  20. Vivian
    Vivian Junior Member
    I know this is an old thread but your question: Any other reports of higher mileage Prius going through CV joints or axles (in cases where the boot wasn't compromised or worn and grease was still in place)? Is what I am experiencing right now on my 2004. I am 7 miles short of 150k. I have had the same type of knocking on and off for years. When I have reported it to Toyota when in for oil changes or service they said it was nothing so I have never really thought it could be a problem. It has become more noticeable when backing up and turning the wheel or at stop signs turning either way at slow speeds. So I mentioned it when I went in my oil change and wham they say I need both DR & Pass CV axles and seals $1650.00. Tech's said no cracks or tears in the boots but they show a lot of wear. Please excuse me for using an old thread I am not used to these boards and last time I posted someone accused me of hijacking a post and getting it off topic but I was responding to the post that started the thread. I never posted again cause I wasn't sure what to do... Just trying to make sure I am not getting taken advantage of by the dealership.
