Most Miles Driven On A Prius
Discussion in 'Prime Main Forum (2017-2022)' started by FarTraveler, Nov 13, 2023.
  1. FarTraveler
    FarTraveler Junior Member
    25
    New Jersey
    2023 Prius Prime
    SE
    So what's the most mileage anybody here has put on a Prius? For me it was 425286 miles that I put on my 2014 Prius that I had driven for more than nine years.
  2. Mendel Leisk
    41,544
    On one engine? The brake booster and hybrid battery made it too? Lots of it on plug-in power? @bisco should be interested.
  3. FarTraveler
    25
    New Jersey
    2023 Prius Prime
    SE
    No I did have to have the gasoline engine replaced after about 300,000 miles but the hybrid battery lasted for as long as I had the car. Although the brakes were starting to go when I traded the car in.
  4. ColoradoBoo
    ColoradoBoo Senior Member
    1,241
    833
    Monument, Colorado USA
  5. bisco
    52,013
    Was it a plug in?
  6. ColoradoBoo
    1,241
    833
    No looks like an LE, not even AWD version. I'd be interested in his maintenance schedule on it.
  7. Mendel Leisk
    41,544
    Keep on top of EGR cleaning. ASAP if it’s never been done, and 50k thereafter. See my signature (on a phone turn it landscape see signature).
  8. ColoradoBoo
    1,241
    833
    Is the EGR an issue in the Gen 4? I've never done an EGR cleaning in the 2017.
  9. Mendel Leisk
    41,544
    Yeah just noticed, he’s posted in “prime” forum, but says it’s a 2014.
  10. bisco
    52,013
    i'm confused, but that's nothing new
    vvillovv likes this.
  11. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    Very understandable seein the OP is talkin about a (2014 high mileage Prius) and the profile says (2012 PiP /model Prime Plus)
    I wender too ???
  12. FarTraveler
    25
    New Jersey
    2023 Prius Prime
    SE
    Yes
  13. FarTraveler
    25
    New Jersey
    2023 Prius Prime
    SE
    I had made an error in my profile, Im driving a 2023 Prius Prime right now. Before that I was driving a 2014 Prius Plug In. I've fixed the error in my profile, thanks for bringing it to my attention.
    bisco, ColoradoBoo and vvillovv like this.
  14. Mendel Leisk
    41,544
    ^ Isn’t PriusChat infrastructure a gas? The 3 posts above all show as #13.
    KCWhitney and ColoradoBoo like this.
  15. vvillovv
    4,321
    1,510
    NY
    Doesn't that make it easier for Tideland to remove the extra 2 posts of the same content without screwing with post counts.
    It's not usually to difficult to keep from posting multiples or if you do see your post showing up more than once just reporting it as a multiple so the mod at least knows where they are and can fix it if / when time permits..
    bisco and Mendel Leisk like this.
  16. bisco
    52,013
    What was the question again?
  17. FarTraveler
    25
    New Jersey
    2023 Prius Prime
    SE
    I was having some technical difficulties and accidentally posted the same post three times, Im trying to see it there's any way to have the extra two posts erased.
  18. FarTraveler
    25
    New Jersey
    2023 Prius Prime
    SE
    The question was, what's the most miles you've ever put on a Prius.
  19. bisco
    52,013
    Right!
    I’ve never owned one beyond 87,000, and that only happened because of Covid
  20. vvillovv
    4,321
    1,510
    NY
    You're not alone about the multiple post things so don't worry about it too much.
    If you find a "Report" this post button around any of the multiple posts, just clicking on one of the posts report button and letting the mod(s) know there is are an extra post or two of the same content ( multiple posts ) and include the URL of the post in the report, whenever the mod(s) have time to review the report (and there are probably a lot of reports currently, so please be patient ) the mod(s) will handle the report, and typically remove any extra posts of the same content. ;)
  21. Mendel Leisk
    41,544
    Just click the Report Button below the duplicate posts. Only thing, the site is rampant with such posts, due to some bug, and the site owner is basically MIA. There's one adminstrator on clean-up duty, and he's likely swamped. Best tactic is just fugedaboutit.
    vvillovv and Trollbait like this.
  22. Mendel Leisk
    41,544
    We're on the cusp of 100k. Kilometers... :unsure:
    @ASRDogman is somewhere around 350k miles. He's cognizant of of all the mechanical foibles (this site helps immeasurably), was a professional mechanic, and just finally DIY'd his head gasket. Still on original engine. (y)(y)(y)
