230K miles, weirdest noise, my friend said it is normal but never heard it before on other Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by franksrental, Nov 11, 2023.
  1. franksrental
    franksrental Junior Member
    29
    usa
    Hello there,
    My prius at 225K miles after a 2000 mile trip started making a strange sound particularly when you are going uphill, but lately audible at lower RPMs and speeds when you are accelerating..
    This was recorded at about 75MPH going uphill
    Recorder
    It sounds as if the car is revving up and down but RPMs were constant 3800. Battery level seemed normal at 75%, car responsive as usual. Just this sound that almost sounds like the sound from a food processor, like something spinning around if it makes sense.
    thank you in advance!
  2. franksrental
    29
    usa
    also no check engine lights or apparent codes
  3. PriusCamper
    PriusCamper Senior Member
    13,071
    5,306
    Pacific Northwest, USA
    Sounds normal to me...
  4. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    Sounds like some kind of resonation. Can't say I've ever noticed it in my car, so I'd hesitate to call it normal. But, is it bad? Idk.
  5. bisco
    52,393
    anything loose underneath?
  6. Goodcitizen
    Goodcitizen Member
    75
    30
    Cali
    Exhaust noise? Is it the oem cat?
  7. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    879
    Monument, Colorado USA
    Hmmm....hard to know for sure. My first thought was about the transmission....has it been serviced regularly or lately? If not, I'd do that before anything else. (Just a drain and fill on them but use Toyota tranny fluid...I believe the 2011 uses the WS.)
  8. pasadena_commut
    pasadena_commut Senior Member
    2,857
    850
    Southern California
    Check all the plastic shields. One may be torn and hanging down onto something that is rotating, or it could be just loose and flapping around in the breeze with some periodicity.
    If the front is jacked up (securely!), the car turned on, and the front wheels spun at similar RPM does the sound occur?
    Are all the windows firmly up? My car can get into a rhythmic sort of huffing sound at around 50 mph when the windows are down part way. (Only observed it a few times, probably analogous to a huge flute.)
  9. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    do the tires have anything stuck in them?
  10. ColoradoBoo
    1,271
    879
    Good ideas! Last summer, we had our Tundra and camper out in the mountains and when I would hit 50 mph or more, I'd hear a little thumping noise....I turned off the radio to hear it better and it was on the front/right side. When we stopped for gas, I looked around and the Tundra has a strange little cloth flap inside the front wheelwells covering up the lower part of the engine. The left side came off years ago the the right side was down to just one clip left, so high winds would make it flap. I just removed it....problem solved. (I have looked on Toyota parts sites for replacements and clips but, so far, haven't found them...I think I can live without them.)
  11. pasadena_commut
    2,857
    850
    Southern California
    Yeah. When I post now and it spins for a long time I open another tab and check if the post has made it through, and if yes, close the first window. It cuts way down on double posts.
    Tideland Prius likes this.
  12. Doug McC
    Doug McC Senior Member
    1,082
    421
    Midwest
    2022 Prius
    Guessing that method didn’t work for this post.
    ColoradoBoo likes this.
  13. pasadena_commut
    2,857
    850
    Southern California
    It did not. Checked in the other tab and there was nothing there, so hit post again, and it ended up being a double post. I had waited a good 30s before checking the other tab, maybe I should extend that to 60s.
    Or even better, the IT folks maintaining this site could fix whatever it is that is taking so long for posts to post and report back to the user's browser!
  14. Mendel Leisk
    41,909
    I hit refresh (F5 on a pc), the little semi-circular arrow at right end of address field in Safari on iPhone) a boatload of times, after the little (never successful) "working" symbol quits moving. Sometimes that works, sometimes not. If not, wait a bit longer, cross fingers, hit "post reply" one more time.
  15. franksrental
    29
    usa
    thanks for the reply GC. I bought it few months ago and they told me the catalythic converter was replaced. So I think you are maybe up to something...
    also after better listening to it, it starts to sound as if air is getting somewhere in the engine where it should not. Similar sound as when you drive with partially lowered window in your car. So I was thinking maybe loose in an intake or similar?
  16. franksrental
    29
    usa
    Thanks for the reply! I do have some loose shields down there. So I need to jack it up and check carefully. Even if it is weird because as soon as you pull up the gas pedal the noise stops. So it is engine related. But maybe the vibration disappears when the engine stops?
  17. franksrental
    29
    usa
