plastic undercarriage cover - Prius 2023 XLE AWD
Discussion in 'Gen 5 Prius Main Forum' started by apezam1, Nov 17, 2023.
  1. apezam1
    apezam1 Junior Member
    2023 Prius
    XLE AWD-e
    I hit a branch and it ripped portion of the plastic undercarriage cover clear off. It is on Driver side towards the back. Took it to the dealer and they want diagnostic plus $450 for ordering new cover. I was wondering if there is a way to find a part number And buy it elsewhere? Many thanks
  2. otatrant
    otatrant Active Member
    240
    156
    San Francisco
    2023 Prius Prime
    XSE Premium
    You can buy an hour of access for about $4.00 to toyota-tech.eu which will give you access to parts list and diagrams. Once you have the part number you can see if you can find a better price online.
  3. 23PriLE
    23PriLE Member
    95
    67
    North Central Florida
    2023 Prius
    $450? Seriously?? And what is there to "diagnose"? It's pretty obvious what's damaged.
    Can't tell from the pics . . . is the expanse of the cover actually torn up? It looks like the damage is confined to the area where it attaches to the chassis. If so, I'd be fixin' that with super glue and/or nylon cable ties.
    My old '98 Honda Accord Coupe had a fairly large plastic cover in the front and the mounting holes got ripped from parking too close to a high curb stop. I just poked a couple small holes in the area next to the torn ones and used heavy duty nylon cable ties to secure it. Worked just fine and held for years. Cost: about 50 cents.
    One of the things I really like about the Prius is that the front clears curb stops easily. It has considerably more clearance than my old Accord or my '08 Civic Coupe.
    Trollbait likes this.
  4. Mendel Leisk
    40,977
    #4 Mendel Leisk, Nov 17, 2023
  5. Trollbait
    12,432
    I'll second the zip ties, glue, and/or duct tape repair. No one is going to see it. As long as it is secure enough to not be rattling, it is doing its job.
  6. BiomedO1
    3,148
    1,667
    SacTown, Ca
    That's highway robbery!!!
    IMHO,
    1. I'd remove that plastic fastener.
    2. drill 3 small holes 90 degrees apart on the main cover around the broken attachment point about 1/2 to 3/4 inch back from the edge.
    3. then run zip-ties through those holes and that plastic fastener mounting point.
    You'll have to cut those zip-ties, if you remove that cover - but zip-ties are a lot cheaper than those plastic fasteners...
  7. Mendel Leisk
    40,977
    @apezam1 can you get the car raised a bit, and a more overall picture? There’s likely some cheap and effective fixes. Taking the broken piece right off for repair would be good. There’s usually a way to repair that’ll be solid and last, cost peanuts.
  8. AndersOne
    AndersOne Active Member
    334
    193
    Europe
    2023 Prius Prime
    I had something similar in my current car - broke some undercoverplastic while doing a wild manover over some hidden curb. It was not that bad so I waited for my next official dealer inspection appointment where we could properly look below the car. They just fixed it too with zipties as they said its not worth it to properly replace it.
  9. vvillovv
    vvillovv Senior Member
    4,320
    1,508
    NY
    The part number for the engine undercover is
    Toyota 51410-47080 COVER ASSY, ENGINE U
    5141047080
    $185 - $265 + shipping - for the main cover assembly, depending on where you find it listed
    It looks like there are 4 or 5 pieces that attach to it or attach around it. Good idea to remove it and take a look at exactly what part(s) you need.
  10. Mendel Leisk
    40,977
    Where did you find that? I got nowhere fast looking at Toyota USA (revamped) website.
  11. vvillovv
    4,320
    1,508
    NY
    parts.toyota.com - enter year - model - trim than search engine under cover
    that's where I got the 4 or 5 other assorted pieces to the puzzle.
    keyed in a browser search of the main cover part number
    and got a second hit at
    toyotapartsdeal
    At parts.toyota I looked around the list too --- I swear they have every single oring nujt bold stud gasket body and engine part for the 2023 models listed individually. :LOL:
    when I keyed in 2023 at toyotapartsdeal it went straight to the BZ4X
    I didn't try adding another car, but I deleted the bz4x and tried the make model trim entry again and it went right back to bz4x. Yeah gettin used to the changes for this gen is gonna take a while.
    #11 vvillovv, Nov 19, 2023
