2005 Prius - New Brake Actuator vs Entire New ABS System?
Discussion in 'Gen 2 Prius Main Forum' started by Ruby2005, Nov 29, 2023.
  1. Ruby2005
    Ruby2005 Junior Member
    17
    everyone!
    I have a 2005 Prius with barely 60,000 miles on it. (-Yes, you read that right; the previous owners barely drove it!)
    I've been getting the dreaded buzzing while driving about every 30 seconds in a rhythmic fashion, as well as the occasional 'seal barking' when my foot is on the brake pedal while stopped.
    My car will also kind of 'shimmy' when braking at low speeds.
    Yesterday after work, I turned on my car and got a loud BEEEEEEEEEEP! for about 5 seconds, and it threw up lights on the dash.
    I emailed my mechanic about getting an estimate for the brake actuator, and he came back with an estimate of OVER $3,800 to replace the ENTIRE ABS system. They say that it's one piece for the Gen 2s!
    I only have about $3,000 in total savings, and no credit card. My credit is ok, and my job pays for cost of living, but that's about it.
    I have no idea as to what's the best scenario in this case, or even if the mechanic is correct. Is he?
    Please help.
    #1 Ruby2005, Nov 29, 2023
  2. ChapmanF
    18,131
    "ENTIRE ABS system" isn't really a thing. If he really meant that, he'd be talking about the actuator, the ECU under the dash, and a pile of other parts and brake lines.
    He's surely just talking about the actuator assembly. The Gen 2 actuator assembly also includes the accumulator and pump, which were a separate assembly in Gen 1, and again in Gen 3. So, in that respect, the Gen 2 actuator assembly is "one piece" compared to those.
    So for your Gen 2, there's not really much of a question here. You and your mechanic are both talking about a replacement of the Gen 2 brake actuator assembly, and the only real question is whether the price can be improved on.
  3. Ruby2005
    17
    Thank you.
    The invoice says
    ABS hydraulic assembly: $2,115.47
    ABS Actuator remove & replace: $567.00
    ABS Actuator Resistor remove & replace: $702.00
    Brake Inspection: $135.00
    I just got another quote from a place that *says* that they work on Priuses, and gave me a quote of $2,768. Which is still incredibly expensive for me.
    The place has really good reviews, though.
    #3 Ruby2005, Nov 29, 2023
    macondo100 likes this.
  4. ChapmanF
    18,131
    The resistor is tucked up under the top of the dash in a place not easy to reach. If a shop were going to remove the upper dash for easier access, I could imagine that sort of a labor charge for it.
    Although a new actuator comes with a new resistor, not everybody bothers to change the resistor. I even remember seeing at least one thread where somebody wanted to change it and managed to do it from below without removing the dash top.
  5. bisco
    51,884
    if you're near tampa, give tampa hybrids a call. not sure if they work on gen 2.
    if not, call a few dealers. i think around $2,500. is the going rate
    #5 bisco, Nov 29, 2023
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    I've done several of these brake actuator jobs, including swapping the resistor. The resistor can be changed in 20 minutes just by removing the left dash vent so you can see better while reaching up inside. Resistor is mounted on the left side wall using one 10mm headed fastener. A bit awkward, but not difficult or time consuming. EVERY resistor I've seen has been identical, part # 44535-47050 193.6 milli-ohms. I replace them when installing a new actuator, just because it comes with it, and if I were a customer who just paid $1200 for a new actuator from Toyota, I would want ALL the new parts installed. Does the resistor HAVE to be swapped?..no.
    And the actuator can be purchased online for <1200 bucks all day long.....
    #6 TMR-JWAP, Nov 29, 2023
  7. Ruby2005
    17
    I called around to the Toyota dealers just to see their rates. Surprisingly, it was the cheapest with a guesstimate of $2,200.
    The service advisor there also told me to call Toyota corporate to see if they'd cover anything at all with the repair now that it was out of warranty.
    After being shuffled around, the answer that I got back was that "They can no longer offer any assistance or provide support on this issues as it was extended twice. And that the repair is "not termed a safety recall; it's an enhancement," so wouldn't be covered.
    #ThanksToyota
  8. bisco
    51,884
    well, you can't really argue with 18 years
    Rph74 likes this.
  9. pasadena_commut
    pasadena_commut Senior Member
    2,609
    771
    Southern California
    Regarding the resistor - isn't it possible to test it by putting a multimeter on a wire and ground (or two wires) somewhere? My experience with bad resistors is that they either are in spec and are not physically damaged, and you leave them, or they are bad in one or both of those ways and you change them.
  10. ChapmanF
    18,131
    Hard to practically test a 193.6 milli-ohm resistor without a milliohmmeter, a specialized instrument not everyone'll have lying around. Here's one that Toyota recommends for jobs that need that kind of test.
    (Notice the double-wire, source+sense test leads with Kelvin clamps, to eliminate the test lead resistance error that you normally don't worry about when measuring bigger resistances.)
  11. rjparker
    10,119
    6,281
    The problem with Prius brake actuators is no one has figured out how to rebuild them - so there are no aftermarket options other than straight out used.
    Even used is a crap shoot since the labor is the same and you could end up with another bad part or a used part that quickly fails.
    Considering a complete failure of your actuator may suddenly increase braking distance and eliminate stability control leading to an accident, new is the way to go.
    Concerning the resistor, I would arrange for it to be left out unless it is clearly needed after the new actuator is installed. Save the part and its labor cost for now and most likely forever.
  12. pasadena_commut
    2,609
    771
    Southern California
    Well yeah, sure, but do these ABS resistors really fail by going from .2 Ohms to .3 Ohms, which would require a tool like that, or do they fail by going open, or at least to several Ohms? Blower motor resistors, which also have a very low resistance, tend to test open, or be pretty obviously burned up. I guess some resistors could short across parts of a wire coil and end up with a lower resistance than specified, but I cannot recall ever reading of a car where one of the fan speeds was going quicker than it should have due to that sort of failure.
  13. ChapmanF
    18,131
    I don't know; I'm not sure I've ever seen a report of one failing at all. I'm not completely sure why Toyota always supplies one along with a new actuator. The idea that they are carefully matched to each pump motor doesn't seem to hold up with TMR-JWAP seeing the same 193.6 mΩ value for every one.
    If the resistor were to fail open (or some extra high resistance), there'd be no low-speed pumping, so if you had that symptom, it might be worth checking.
  14. macondo100
    macondo100 Junior Member
    40
    US
    My quote was about the same here in NOVA. I was skeptical about the resistor charge but apparently they need to pop the panels in the front to get to it; not sure you can really get to it from the bottom, as others claim.
    The OEM actuator with resistor was about $1300 (tax included); the replacement cost for the labor was $1515, including a new inverter pump and rear (drum) brakes. Was it worth for nearly 3K the total cost? It was either that or the hassle to buy a used car for a lot more and possibly deal with more car issues; after the repair, that long beep, knocking, and vibrating noise coming from the actuator went away and my Prius is smoother and even getting better mileage. I wouldn't be so comfortable had I put a used actuator instead and not having replaced the resistor. @ 208K miles, I'm hoping this Prius will give me another 50K-100k miles.
  15. ChapmanF
    18,131
    I would guess that the others who report having done it might be on to something.
  16. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    I've done this a handful of times. The resistor has always been stamped with identical values and is replaceable by reaching up from the bottom. It's mounted by one 10mm hex head bolt on the driver left sidewall. Remove the left dash vent to help with the view. Easy squeezy....
  17. RickBthere
    RickBthere Junior Member
    Silver Spring,MD
    Hi Macondo,
    Where in NOVA did you take your Prius for the Actuator job? I'm across the river in MD and having the telltale signs (whirring every 20 seconds, brakes barking when engaged at a stop. When I turn my car on, if I put the transmission into drive right away, there is very little braking. I've also got a 2006.
