Is Toyota WS Fluid "Liquid Gold"?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tnt01prius, Aug 25, 2022.
  1. ETP
    2,803
    1,170
    Auburdale FL
    I read an article that I cannot find anymore that Toyota had developed a new CVT Hybrid fluid. Better MPG supposedly.
  2. Mendel Leisk
    41,849
    It’s for 5th gen transaxle IIRC?
  3. Tombukt2
    13,335
    2,401
    Well we're taking the risk we've been using I don't even know what Castro's equivalent to the CVT fluid needed for these hybrid type setups heading into 400K and transmissions have not even been on the radar since the car's been on the road some things have been but the CVT MG1 and 2 etc not at all I've only read about those failures haven't personally seen one or know of one in my area that's been changed because it failed. Now because they got broken in wrecks or been up and crushed in an accident or something like that absolutely and the people generally didn't fare so well either but just them breaking down because transmission fluid broke down the varnish on the electric motor parts not that I know of but I'm sure it possible.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,508
    2,487
    Taylors, SC
    I'm wondering if there is a confusion between WS and FE cvt fluid?
  5. Tombukt2
    13,335
    2,401
    Probably somewhere in the readings not necessarily here but in other places where I've read about the Toyota CVT transmission fluid where people are talking about the stuff like it's gold or platinum or titanium or some such nonsense for the regular non-hybrid non motor generated transmissions etc I would be using the regular Castrol or whatever meets the spec for the setup. I know a lot of these CVTs and other vehicles not necessarily the Prius are having lots of problems and I don't think it's really fluid related so I'm kind of leery of them fitted behind regular gas engines even like in the Yaris I'd rather just have a five-speed I think.
  6. Mendel Leisk
    41,849
    Toyota ATF WS is not expensive. :confused:
  7. Georgina Rudkus
    3,508
    2,487
    Taylors, SC
    FE is really expensive.
  8. rjparker
    10,436
    6,544
    New gen5 transaxle fluid used on 2.0L Prius and Corolla hybrids
    e-Transaxle Fluid TE
    P/N: 08886-02605
    Introduced in 2022. Fluid for hybrid transmissions, intended primarily for cooling of motor-generators. Differs from ATF in reduced viscosity.
    #48 rjparker, Dec 2, 2023
  9. Georgina Rudkus
    3,508
    2,487
    Taylors, SC
  10. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Agreed, which is why I am trying out Valvoline Full Synthetic CVT fluid in my 2016 Toyota Corolla S Plus.
    Just doing drain and fills (2) so far, so I haven't replaced much of the old fluid yet. But the Valvoline CVT fluid is straw colored and not dyed red like the Toyota fluids.
    It was overdue at 78K miles on the odometer.
    It is interesting/concerning that it seems that Valvoline has removed the labelling on the fluid that says it is compatible with Toyota FE and WS.
    So far, no noticeable change in performance or behavior of the CVT transaxle. Only negative so far is that the Valvoline fluid is quite smelly.
    SM-G781V ?
    Georgina Rudkus likes this.
  11. douglasjre
    douglasjre Senior Member
    2,202
    736
    Null, NL
    World standard seems to be just Dexron/Mercon latest edition. Been putting Maxlife dex/merc/LV VI in dozens of turd gen Priuses for a decade and no issues w mine or others
  12. ChapmanF
    18,484
