Diesel - stupid mistake
Discussion in 'Prime Technical Discussion' started by medicis, Dec 4, 2023.
  1. medicis
    medicis Junior Member
    I still don't know how it could have happened but it did (senior moment stuff). I now have a few liters of diesel in the tank but fortunately the car has been in full EV mode since. I have drowned it with regular fuel but I know it is sitting at the bottom, conveniently next to the intake.
    I think I should be able to drive in EV to the dealer for a flush but I know there are some cases when the gas engine starts up in EV mode no-matter-what (e.g. for windshield defogger but also in some obscure cases). Hence two questions:
    1. If the gas engine ran for a few minutes before I can curb safely and stop, would the damage be immediate?
    2. Is there a way to disable the gas engine altogether? Maybe a circuit breaker for the fuel pump or something of the kind.
    It's probably not worthwhile to take the risk just to save on towing but no harm in asking.
    Thanks!
    Philippe
  2. rjparker
    9,902
    6,105
    Tow it
    sylvaing and schja01 like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    Accidentally mixing gasoline and diesel fuel - What happens then? (bellperformance.com)
    Currently your biggest problem is getting the tank drained since the diesel is (hopefully) limited to only the tank.
    Run the engine? Now it's in the fuel lines, injectors and cylinders and becomes a bit more expensive to clean out. No dealer is likely to say...we'll just let it ride and see what happens. They're going to want to do the full cleanout. Is it a fatal problem? No one can say for sure, but if it is, once the breakage happens, it's too late to change your mind.
    It sucks, and I've done some sketchy stuff with older cars, forklifts, dingos and such when fuel was accidently mixed, but I don't think I'd risk it with my real ride. I would find a way to drain and fill or dilute the living crapola out of it.
  4. bisco
    51,571
    I wonder if you could get a tube down there to pump most of it out and then fill with gas
